Introdução
The ZPrinter 650 color powder 3D printer has a large electronics module which is somewhat prone to failures. Replacement module is very expensive, it cost around 5000 USD in 2015. What is even worse, the original producer (Z Corporation) was bought out by 3D Systems and they stopped providing spare parts for older (pre-2012) printers. However, I figured out the main reason why the electronic modules fail: a small embedded PC mainboard based on VIA C3 processor. Taiwanese comrades who manufactured the board used a bit too cheap CPU fan and when it stops working, the CPU will burn out. In one instance, the fan started to fail after mere 2 months! You can't replace the CPU (it's soldered to the board), but it's possible to buy a new mainboard. It has part number ENDAT-3220M and can be usually found on Ebay. Ocassionally, it also appears in PC surplus stores and the like, just Google for it. Other Z Corporation printers also use this mainboard, Zprinter 450 and Zprinter 250 for example. Unfortunately, it also depends on production year of the printer, so I recommend to disassemble the printer and check the actual mainboard type before you buy.
WARNING! This repair should be performed only by skilled technician with background in electronics and/or computer service work. Moreover, it includes manipulation with very sensitive electronic components and ESD precautions must be observed during most steps!
The electronics module is very complex and the mainboard is not the only component that can fail. So first you need to verify that your printer really has bad mainboard and not something else.
Normally, the mainboard produces a short beep about 10 seconds after powerup. If it doesn't beep, then it's probably dead.
If it beeps more than once or beeps repeatedly, then the mainboard works, but something else failed (dead CMOS battery, bad memory etc). In that case you can diagnose it like in Step 8.
Another indication is the front display - if it lights up but all pixels stay black like in the photo, then it's likely the mainboard is dead. If it doesn't light up at all, then there is some other problem (dead power supply for the entire electronics module, for example).
Power down the printer and unplug all cables from the electronics module on the back. Remove 6 screws from its cover and put it away.
Power up the printer and let it run for at least 10 minutes. Then place your finger to the board on the back side of the CPU (green arrow). If it's hot (>50 degrees Celsius), it means the CPU had burned out.
You can also check if the original CPU fan works - if it doesn't, then your CPU burned out for sure. See Step 9 as to how to check.
If you confirmed you have bad mainboard and bought a new one, you need to prepare it first.
Firstly, preventively replace the original fan - as I said in introduction, it may fail in a few months. Don't try to skimp here, use the best fluid dynamic bearing fan you can get! I'm using Noctua NF-A4x10 FLX in the photo, but any other 40x40x10 mm fan with 12V 3-pin connector will do. Don't forget to connect the fan cable.
Secondly, preventively replace the original CMOS battery (CR2032 type). The mainboard sat in a warehouse for 8 or more years by now, so the original battery will be dead anyway.
Unplug all cables from the printer and remove 4 screws as indicated. Then gently pull on the left vertical edge of the mainboard. You will feel some resistance as a PCI riser card disconnects (see Step 7 for more details about it).
Place some sort of pedestal on the ground, so the original mainboard wouldn't hang from the cables. I'm using a cardboard box in the photo.
Now you can review all the components you need to move to the new mainboard: 1. DDR memory stick (yellow arrow), 2. small Parallel ATA solid state hard drive (green arrow), 3. power supply converter and connector (purple arrow) and 4. white flat cable (blue arrow) for "power button" header.
This part is a bit tricky, because you need to connect the mainboard onto PCI riser card as you slide it in.
First, place mainboard's connectors on the I/O shield at an angle, as shown in the first photo. Then gently push the left edge of the board and check if the riser card is properly mating with the PCI slot (green arrows in the second photo). If it's OK, push the mainboard all the way onto the hexagonal mounting posts and secure it with screws.
Now you should test if the new mainboard helped (i.e. if it really was the source of the fault). Do NOT connect Ethernet cable at this point, otherwise the printer will not boot.
Connect a PS/2 keyboard and a VGA monitor to the mainboard. Then plug in the power cord to the printer and turn it on. The mainboard should beep and show BIOS logo. It will probably stop there and report corrupted CMOS settings (beause of the battery in Step 4).
Enter the BIOS (Delete or F1 key), and choose Save settings (second photo). This will set and save default CMOS settings and the mainboard will reboot itself. It then should fully boot into printer firmware (ASCII GUI similar to the third photo). Also, the small display at the front of the printer should work now.
When the printer is running, you should check that you've mounted and plugged the new CPU fan correctly. You can see it rotating with a small mirror or you can carefully feel it with your finger, like in the photo.
Tie up the nearby cables, so they can't move and block the fan.
You need to change some settings in the BIOS, otherwise the printer firmware will always freeze as soon as you plug in the Ethernet cable. Specifically, you need to disable some onboard devices to prevent IRQ conflicts (the firmware runs on FreeDOS, which is not Plug and Play OS).
Unfortunately, I don't remember which settings exactly have to be changed, but I made photos on a working printer, so you can use them as a guide.
Ifixit allows only 3 photos per step, so here are some more BIOS settings. Incidentally, I think the last one (Peripheral Setup) is the most important one.
Don't forget to save the new settings when you're done. Then let the printer boot into its ASCII GUI.
Connect Ethernet cable to the printer and check the ASCII GUI. Normally, some values change every second and they should continue to do so after you plug in the cable. If the firmware freezes, you need to check the BIOS settings again.
Moreover, the firmware displays various information during boot (second photo). If you reboot the printer and it always freezes at a particular stage, then that's the likely culprit. Unfortunately, it seems the only way to do a reboot from frozen firmware is by turning the printer off and on again.
The printer should now work normally. You should be immediately able to connect to it with ZPrint or 3DPrint software, because all settings were stored on its internal HDD. But keep in mind the new mainboard has different MAC address, so some network configuration changes in your institution/workplace may be necessary.
Finally, you should turn off the printer, disconnect all cables and put back cover on the electronics module. That completes the repair.
4 outras pessoas concluíram este guia.
27 comentários
Please send me an image of the hd to aylward Edward at Gmail. Thanks
Check your mail if it arrived, our mailserver antivirus is a bit overzealous when it comes to "non-standard” attachments.
Everyone! Please don’t provide any help or information to Edward Aylward! He is from Noble 3D Printers company which defrauded my employer - we ordered binders for 1000 USD and they never delivered them. And we weren’t the only ones who they cheated:
Thank you for your guide. I have a used 450 and its mother board is/was bad. Someone replaced it with a different one and I am struggling with the board, still. The fan was dead on the NEW board! So I am betting its dead too. What a load of you know what for a $25,000 machine when it was new. Regards. Cismontguy Free Union VA. USA
A different board? You mean different part number than ENDAT-3220M? Please post its type or photos.
