Ir para o conteúdo principal
ZD-N Plus Wireless Controller Rumble Motor Replacement
O que você precisa
  1. ZD-N Plus Wireless Controller Rumble Motor Replacement, Back Panel: passo 1, imagem 1 %32
    • Remove the seven 12mm JIS #00 screws that hold the back panel in place.
  2. ZD-N Plus Wireless Controller Rumble Motor Replacement: passo 2, imagem 1 %32 ZD-N Plus Wireless Controller Rumble Motor Replacement: passo 2, imagem 2 %32
    • Lift up on the back panel of the ZD-N Plus to remove it from the rest of the controller.
  3. ZD-N Plus Wireless Controller Rumble Motor Replacement, Battery: passo 3, imagem 1 %32
    • Use an opening tool to pry the battery from its original position.
    • The battery is glued on, so this may take some effort.
  4. ZD-N Plus Wireless Controller Rumble Motor Replacement: passo 4, imagem 1 %32 ZD-N Plus Wireless Controller Rumble Motor Replacement: passo 4, imagem 2 %32
    • Use an opening tool to pry the connector away from the two metallic prongs.
    • The parts are built to stay together, so this may take some effort.
    • Be careful to not warp the prongs in the process.
  5. ZD-N Plus Wireless Controller Rumble Motor Replacement: passo 5, imagem 1 %32 ZD-N Plus Wireless Controller Rumble Motor Replacement: passo 5, imagem 2 %32
    • Remove the battery from the controller.
  6. ZD-N Plus Wireless Controller Rumble Motor Replacement, Rumble Motor: passo 6, imagem 1 %32 ZD-N Plus Wireless Controller Rumble Motor Replacement, Rumble Motor: passo 6, imagem 2 %32
    • Remove the electrical connector attaching each rumble motor to the controller.
    • Lift up on the circular section of the rumble to remove it from the controller.
Conclusão
Jessica Newhouse
Membro desde: 10/17/19
73 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Duração total: 264
