Ir para o conteúdo principal
ZCWA BR151 Water Filter Replacement
O que você precisa
  1. ZCWA BR151 Water Filter Replacement, Water Tank: passo 1, imagem 1 %32
    • Turn off the device.
  2. ZCWA BR151 Water Filter Replacement: passo 2, imagem 1 %32 ZCWA BR151 Water Filter Replacement: passo 2, imagem 2 %32
    • Remove the water tank by sliding the latch down with a finger and grasping the bottom of the water tank.
    • Pull it out.
  3. ZCWA BR151 Water Filter Replacement, Water Filter: passo 3, imagem 1 %32 ZCWA BR151 Water Filter Replacement, Water Filter: passo 3, imagem 2 %32 ZCWA BR151 Water Filter Replacement, Water Filter: passo 3, imagem 3 %32
    • Remove the filter holders, on the bottom of the water tank, one at a time by maneuvering the spudger under the flaps of the filter holders.
    • Use the spudger to lift enough of the flap up to pinch it between two fingers.
    • Pull the flap up while pinching it to dislodge the filter holder from the water tank.
  4. ZCWA BR151 Water Filter Replacement: passo 4, imagem 1 %32 ZCWA BR151 Water Filter Replacement: passo 4, imagem 2 %32 ZCWA BR151 Water Filter Replacement: passo 4, imagem 3 %32
    • To extract the cotton filters, push the flaps of the filter holders down.
    • Use the tweezers to pull out the filter.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 16
Duração total: 48
