Introdução
The ZCWA BR151’s water filters purify the water before it is used on the floors. If the device is leaking water, refer to the troubleshooting page for instructions on how to correct this. If the filters of the ZCWA BR151 need to be replaced, use this guide to do so. It is easy to access through the removal of only a few pieces. A spudger is needed to complete the installment or replacement of the water tank’s filters. There are no difficult steps in these instructions. Be gentle when handling the filters as they are made of cotton and can easily be torn.
O que você precisa
Remove the filter holders, on the bottom of the water tank, one at a time by maneuvering the spudger under the flaps of the filter holders.
Use the spudger to lift enough of the flap up to pinch it between two fingers.
Pull the flap up while pinching it to dislodge the filter holder from the water tank.
Uma outra pessoa concluiu este guia.
