Ir para o conteúdo principal
ZCWA BR151 Sprayer/Pump Replacement
O que você precisa
  1. ZCWA BR151 Sprayer/Pump Replacement, Water Tank: passo 1, imagem 1 %32
    • Turn off the device.
  2. ZCWA BR151 Sprayer/Pump Replacement: passo 2, imagem 1 %32 ZCWA BR151 Sprayer/Pump Replacement: passo 2, imagem 2 %32
    • Remove the water tank by sliding the latch down with a finger and grasping the bottom of the water tank.
    • Pull it out.
  3. ZCWA BR151 Sprayer/Pump Replacement, Sprayer/Pump: passo 3, imagem 1 %32 ZCWA BR151 Sprayer/Pump Replacement, Sprayer/Pump: passo 3, imagem 2 %32
    • Flip the device over to access the bottom panel.
    • Remove the cloth mop covering by lifting it from the velcro on the plastic mop attachment.
    • Remove the plastic mop attachment by placing your fingers underneath and prying it up.
  4. ZCWA BR151 Sprayer/Pump Replacement: passo 4, imagem 1 %32
    • Remove the six 6 mm screws on the bumper guards using a Phillips #0 screwdriver.
    • Remove the bumper guards by lifting them.
  5. ZCWA BR151 Sprayer/Pump Replacement: passo 5, imagem 1 %32
    • Use a Phillips #1 screwdriver to remove the ten 10 mm screws from the bottom plate.
  6. ZCWA BR151 Sprayer/Pump Replacement: passo 6, imagem 1 %32 ZCWA BR151 Sprayer/Pump Replacement: passo 6, imagem 2 %32
    • Carefully lift the bottom panel off of the top.
    • The top and bottom panels are attached by a set of wires. They will not fully detach at this point.
    • Gently place the bottom of the device on your workspace surface, wheels down, exposing the inner workings of the device.
  7. ZCWA BR151 Sprayer/Pump Replacement: passo 7, imagem 1 %32
    • Though optional, we recommend separating the top and bottom panels for easy access to the sprayer/pump.
    • Pinch the wire bracket that is on the top panel while pulling the bracket away.
    • Pull the cable away from the connector in the same direction as the individual wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
  8. ZCWA BR151 Sprayer/Pump Replacement: passo 8, imagem 1 %32 ZCWA BR151 Sprayer/Pump Replacement: passo 8, imagem 2 %32 ZCWA BR151 Sprayer/Pump Replacement: passo 8, imagem 3 %32
    • The sprayer is slotted in place with grooves. Slide up the sprayer by lifting it up with your fingers.
    • The sprayer/pump should loosely be free, except for wires connecting it to the motherboard.
  9. ZCWA BR151 Sprayer/Pump Replacement: passo 9, imagem 1 %32 ZCWA BR151 Sprayer/Pump Replacement: passo 9, imagem 2 %32 ZCWA BR151 Sprayer/Pump Replacement: passo 9, imagem 3 %32
    • Turn the device around so that the motherboard is closest to you.
    • Track the red and black wire cables from the sprayer/pump to the motherboard.
    • Remove the sprayer/pump wiring from the port on the motherboard by pinching the silver brackets and pull the wire casing away from the motherboard.
    • Remove the sprayer/pump from the vacuum.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 49
Ao todo: 1,025
