Introdução
The guide instructs you to replace the spring clip or (also known as the arm clip) at the arm attachment on the Yuneec Typhoon H.
The spring clips usually get broken during a crash.
O que você precisa
Remove the broken arm clip by pinching the metal top and then pull it out with an upward force.
