Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Introdução
The guide instructs you to replace the spring clip or (also known as the arm clip) at the arm attachment on the Yuneec Typhoon H.
The spring clips usually get broken during a crash.
Peças
Nenhum componente especificado.
  1. Using a JIS #00 screwdriver, unscrew the 3mm oval screw. The oval screw is hard to remove once fully unscrewed, to remove the screw flip the drone upside down to have the screw fall out. The oval screw is hard to remove once fully unscrewed, to remove the screw flip the drone upside down to have the screw fall out.
    • Using a JIS #00 screwdriver, unscrew the 3mm oval screw.
    • The oval screw is hard to remove once fully unscrewed, to remove the screw flip the drone upside down to have the screw fall out.
  2. For this step the arm must be bent. Remove the broken arm clip by pinching the metal top and then pull it out with an upward force.
    • For this step the arm must be bent.
    • Remove the broken arm clip by pinching the metal top and then pull it out with an upward force.
    • The Blunt Nose Tweezers may be helpful in removing the arm clip.
Conclusão
Uma outra pessoa concluiu este guia.
Claire Luce
Membro desde: 16/04/2018
347 Reputação
2 Guias de autoria
Equipe
Cal Poly, Team S22-G3, Maness Spring 2018 Membro de Cal Poly, Team S22-G3, Maness Spring 2018
CPSU-MANESS-S18S22G3
4 Membros
5 Guias de autoria
what function does the little screw have?
Ruud - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 18
Duração total: 814
