Introdução
Before you start this replacement, make sure to purchase a new Slip Ring Yaw Motor. Likewise, there are several small screws and parts in this motor, so, make sure not to lose these parts during repair.
O que você precisa
Using the Phillips #000 screwdriver, remove the two 4.9 mm screws on the side of the plastic cover holding the wires together.
Once these screws are removed, press down on this plastic cover to reveal the wires. Pull the locking tabs that are on the end of this piece to completely remove this plastic cover.
Removed the damaged slip ring motor by guiding the wires through the opening in the motor piece. Use a pair of pliers to make sure the wires are pushed through the opening in the center of the motor piece.
Need to Mark the Yaw Motor when removing the screws from the Bottom Gimbal Plate, or your Camera won’t Face to the Front when you reassemble.
To reassemble your device, follow these instructions in reverse order (This process is in the guide steps for reference).
3 outras pessoas executaram este guia.
2 comentários
Ive done all the above but digging out the epoxy it took almost all wire with it i couldve solderd to so what to do now its the white wire by the way the camera still stabalises and points straight just cant manually control
The White or Green wire is most likely not making connection
