Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Introdução
Learn how and where to unscrew the landing gear legs in order to replace broken ones, without breaking your drone more.
Peças
Nenhum componente especificado.
  1. Lift all drone arms up so you can access the landing gear easily. Lift all drone arms up so you can access the landing gear easily.
    • Lift all drone arms up so you can access the landing gear easily.
  2. The Essential Toolkit
    The most helpful tools in our most compact kit.
    Comprar agora
    Comprar agora
  3. Unscrew the 16.9 mm screw at the top of the landing leg with a Phillips #00 screwdriver. Make sure the screw head is not stripped in the process. If stripped, the whole leg, including the internal sensors, will need to be replaced.
    • Unscrew the 16.9 mm screw at the top of the landing leg with a Phillips #00 screwdriver.
    • Make sure the screw head is not stripped in the process.
    • If stripped, the whole leg, including the internal sensors, will need to be replaced.
  4. Pull the landing leg out slowly and remove it from the device.
    • Pull the landing leg out slowly and remove it from the device.
Conclusão
Your Yuneec Typhoon H should now be ready to fly safely again.
Uma outra pessoa concluiu este guia.
Shasta Banchio
Membro desde: 16/04/2018
130 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S22-G3, Maness Spring 2018 Membro de Cal Poly, Team S22-G3, Maness Spring 2018
CPSU-MANESS-S18S22G3
4 Membros
5 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 18
Duração total: 695
