Ir para o conteúdo principal
Yuneec Typhoon H Gimbal Bushing Reattachment
O que você precisa
  1. Yuneec Typhoon H Gimbal Bushing Reattachment, Gimbal Bushing Connectors to Camera Mount: passo 1, imagem 1 %32 Yuneec Typhoon H Gimbal Bushing Reattachment, Gimbal Bushing Connectors to Camera Mount: passo 1, imagem 2 %32
    • In order to repair the camera and camera gimbal, remove the camera configuration from the body of the drone.
    • Pull up on the tab connected to the camera configuration and slide the entire apparatus off.
  2. Yuneec Typhoon H Gimbal Bushing Reattachment: passo 2, imagem 1 %32 Yuneec Typhoon H Gimbal Bushing Reattachment: passo 2, imagem 2 %32 Yuneec Typhoon H Gimbal Bushing Reattachment: passo 2, imagem 3 %32
    • Put the gimbal bushings (the rubber balls) back into the plastic alignment mounts.
    • The circle that is separated from the main body of the bushing should then be inserted into the hole.
    • When pushing these bushings back into place, it is smart to use a skinny tool or toothpick.
Conclusão
To reassemble your device, simply slide the camera mount back onto the bottom of the drone.
Jake Breul
Membro desde: 04/16/18
127 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S22-G3, Maness Spring 2018 Membro de Cal Poly, Team S22-G3, Maness Spring 2018
CPSU-MANESS-S18S22G3
Membros da 4
Autoria de 5 guias
3 comentários
Camera not getting power after crash.
Don - Responder
Crashed drone and camera not getting power anymore. Nothing appears to be broken.
Don - Responder
Did steps. Bushings ok. Camera still won't communicate.
vickiesamus - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 1,603
