Ir para o conteúdo principal
Yuneec Breeze 4K Camera Replacement
O que você precisa
  1. Yuneec Breeze 4K Camera Replacement, Camera: passo 1, imagem 1 %32 Yuneec Breeze 4K Camera Replacement, Camera: passo 1, imagem 2 %32
    • Before you begin start by putting on a ESD wrist strap to prevent ESD damage and remove the battery.
    • Once the battery is taken out, flip over the drone so that the cameras are now facing up.
  2. Yuneec Breeze 4K Camera Replacement: passo 2, imagem 1 %32
    • Using small pliers grip the connector of the wire and pull it out slowly.
  3. Yuneec Breeze 4K Camera Replacement: passo 3, imagem 1 %32
    • Remove the four white rubber dampeners located in each corner of the frame that hold the it in place.
  4. Yuneec Breeze 4K Camera Replacement: passo 4, imagem 1 %32
    • Unplug the two vertical plugs located in the rear of the M7 board.
  5. Yuneec Breeze 4K Camera Replacement: passo 5, imagem 1 %32
    • Slightly lift the M7 board to remove the two plugs located under the rear of the board.
  6. Yuneec Breeze 4K Camera Replacement: passo 6, imagem 1 %32
    • Once all plugs on top of the M7 board are disconnected, carefully lift the M7 board onto its side and remove all plugs on the bottom.
  7. Yuneec Breeze 4K Camera Replacement: passo 7, imagem 1 %32 Yuneec Breeze 4K Camera Replacement: passo 7, imagem 2 %32
    • Tilt the M7 board onto its side. Using the Phillips #00 screwdriver remove the two black screws connected to the large black two pronged input.
  8. Yuneec Breeze 4K Camera Replacement: passo 8, imagem 1 %32
    • Using a pair of pliers pull apart the battery connector.
  9. Yuneec Breeze 4K Camera Replacement: passo 9, imagem 1 %32
    • Flip over the entire frame along with the M7 board and the A9 board.
  10. Yuneec Breeze 4K Camera Replacement: passo 10, imagem 1 %32
    • There will be 4 screws that hold the A9 board together. Using a H1.5 Alan bit unscrew those bolts to take the A9 board apart.
  11. Yuneec Breeze 4K Camera Replacement: passo 11, imagem 1 %32
    • Unplug the only wire that is connected to the A9 board.
  12. Yuneec Breeze 4K Camera Replacement: passo 12, imagem 1 %32
    • Pull apart the frame from the other board. The camera will be connected by a plug and it should pull out easily.
  13. Yuneec Breeze 4K Camera Replacement: passo 13, imagem 1 %32
    • Unscrew the four screws that are holding the camera to the frame.
Conclusão
3 outras pessoas executaram este guia.
Wes Knutson
Membro desde: 10/04/18
481 Reputação
Autoria de 3 guias
Equipe
UW Stout, Team S6-G5, Ogden Fall 2018 Membro de UW Stout, Team S6-G5, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G5
Membros da 4
Autoria de 4 guias
Um comentário
Excellent! I don’t think that the process could of have been any more clear than this.
neonjohn25 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Duração total: 1,844
