Ir para o conteúdo principal
Yujin Robot iCLEBO Arte Dust Bin Replacement
O que você precisa
  1. Yujin Robot iCLEBO Arte Dust Bin Replacement, Dust Bin: passo 1, imagem 1 %32
    • Remove the dust bin by gently pressing the silver button on top of the vacuum until the bin releases.
  2. Yujin Robot iCLEBO Arte Dust Bin Replacement: passo 2, imagem 1 %32 Yujin Robot iCLEBO Arte Dust Bin Replacement: passo 2, imagem 2 %32
    • Grip the bottom of the dust bin. Push up on the tabs as indicated by the yellow arrows.
    • Empty contents of bin into waste receptacle and rinse with water as needed.
Conclusão
To reassemble the dust bin, follow these instructions in reverse order.
Trent Treiber
Membro desde: 02/28/17
204 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team S2-G3, Nance Spring 2017 Membro de USF Tampa, Team S2-G3, Nance Spring 2017
USFT-NANCE-S17S2G3
Membros da 4
Autoria de 14 guias
3 comentários
My machine says C3 even though the dust bin is successfully in place. Now what? Works fine on hardwood floors.
Amy Abbiatti - Responder
C3 error even though dustbin is installed correctly. Works fine on hardwood floors. Now what?
I also get C3 error when dustbin is clean and installed correctly - now what?
Philip Melese - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 1,115
