Ir para o conteúdo principal
Yoton YB02 Monitor Speaker Replacement
O que você precisa
  1. Yoton YB02 Monitor Speaker Replacement, Monitor Speaker: passo 1, imagem 1 %32
    • Use a Phillips #0 screwdriver to remove the four 7 mm screws from the back panel of the monitor.
  2. Yoton YB02 Monitor Speaker Replacement: passo 2, imagem 1 %32 Yoton YB02 Monitor Speaker Replacement: passo 2, imagem 2 %32
    • Use a plastic opening tool to separate the back panel from the monitor.
    • It is recommended to start from a corner, and run the tool along the edge of the panel.
  3. Yoton YB02 Monitor Speaker Replacement: passo 3, imagem 1 %32 Yoton YB02 Monitor Speaker Replacement: passo 3, imagem 2 %32
    • Using the plastic tool, disconnect the cables connecting the speaker to the motherboard.
  4. Yoton YB02 Monitor Speaker Replacement: passo 4, imagem 1 %32 Yoton YB02 Monitor Speaker Replacement: passo 4, imagem 2 %32
    • Using the metal spudger, pry off the speaker from the back panel.
    • It is recommended to scrape off excess glue holding the speaker to the panel with the spudger.
Conclusão
hsisson
Membro desde: 02/15/24
811 Reputação
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 7
Últimos 30 dias: 11
Duração total: 34
