Ir para o conteúdo principal
Yoton YB02 Camera Stand Speaker Replacement
O que você precisa
  1. Yoton YB02 Camera Stand Speaker Replacement, Camera Stand Speaker: passo 1, imagem 1 %32 Yoton YB02 Camera Stand Speaker Replacement, Camera Stand Speaker: passo 1, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the single 7 mm screw from the back of the panel from the camera.
  2. Yoton YB02 Camera Stand Speaker Replacement: passo 2, imagem 1 %32 Yoton YB02 Camera Stand Speaker Replacement: passo 2, imagem 2 %32
    • Use a metal spudger to pry off the back panel from the camera.
    • It is recommended to pry at the edges of the panel and run through the edge of the panel.
  3. Yoton YB02 Camera Stand Speaker Replacement: passo 3, imagem 1 %32
    • Carefully move the motherboard out of the way to access the camera speaker.
  4. Yoton YB02 Camera Stand Speaker Replacement: passo 4, imagem 1 %32
    • Use a plastic opening tool to remove the camera speaker from the panel.
    • It is recommended to remove or scrape off the excess glue holding the camera in place.
  5. Yoton YB02 Camera Stand Speaker Replacement: passo 5, imagem 1 %32 Yoton YB02 Camera Stand Speaker Replacement: passo 5, imagem 2 %32 Yoton YB02 Camera Stand Speaker Replacement: passo 5, imagem 3 %32
    • With the plastic opening tool, detach the cable from the speaker to the motherboard at the clips.
Conclusão
hsisson
Membro desde: 02/15/24
811 Reputação
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 26
