Ir para o conteúdo principal
Yamaha NS-AW190BL Rear Casing Replacement
O que você precisa
  1. Yamaha NS-AW190BL Rear Casing Replacement, Rear Casing: passo 1, imagem 1 %32 Yamaha NS-AW190BL Rear Casing Replacement, Rear Casing: passo 1, imagem 2 %32
    • Remove the six Phillips Head 1.2mm screws on the front side of the speaker.
  2. Yamaha NS-AW190BL Rear Casing Replacement: passo 2, imagem 1 %32 Yamaha NS-AW190BL Rear Casing Replacement: passo 2, imagem 2 %32 Yamaha NS-AW190BL Rear Casing Replacement: passo 2, imagem 3 %32
    • Crack open both parts of the casing carefully.
    • Using a plastic opening tool, wedge open the bottom of the speaker to separate the two parts of the speaker.
  3. Yamaha NS-AW190BL Rear Casing Replacement: passo 3, imagem 1 %32 Yamaha NS-AW190BL Rear Casing Replacement: passo 3, imagem 2 %32 Yamaha NS-AW190BL Rear Casing Replacement: passo 3, imagem 3 %32
    • Remove the cooling foam.
    • Use a metal spudger to push the tab in on the red wire.
    • Repeat the process for the blue wire.
  4. Yamaha NS-AW190BL Rear Casing Replacement: passo 4, imagem 1 %32 Yamaha NS-AW190BL Rear Casing Replacement: passo 4, imagem 2 %32
    • The blue wire can now be removed from its connector.
    • Remove the red wire to free the rear casing.
Conclusão
Nick Ruiz
Membro desde: 02/07/17
331 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 17-3, Blackwell Spring 2017 Membro de USF Tampa, Team 17-3, Blackwell Spring 2017
USFT-BLACKWELL-S17S17G3
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 16
Duração total: 836
