Introdução
This guide will walk you through the process of replacing the input/output panel.
O que você precisa
Remove all four .5 mm Phillips head screws located on the back panel of the device.
Pull out the input/output panel from the back of the device once all four screws are removed.
Uma outra pessoa concluiu este guia.
