O que você precisa
Remove the six Phillips Head 1.2mm screws on the front side of the speaker.
Use the metal spudger to bend down the metal tabs that hold the wires to the terminals. The tabs are small and in between the grooves of the terminal.
Once the wire assembly is removed, the entire front panel and speaker housing should be separated to replace.
Quase terminado!
Conclusão
