Ir para o conteúdo principal
XtremeMac Luna Dissasembly
O que você precisa
  1. XtremeMac Luna Dissasembly, Bottom Panel: passo 1, imagem 1 %32 XtremeMac Luna Dissasembly, Bottom Panel: passo 1, imagem 2 %32 XtremeMac Luna Dissasembly, Bottom Panel: passo 1, imagem 3 %32
    • Flip the device over so that the batteries are closest to you.
    • Remove the battery lid by pressing the battery cover's tab and pulling it away from the device.
    • Push the battery against the spring and lift it out of the casing.
    • Repeat with the other battery.
  2. XtremeMac Luna Dissasembly: passo 2, imagem 1 %32
    • Unscrew all eight 12mm Phillips head screws with a Philips #1 screwdriver.
    • The iFixit 26 bit screwdriver kit will not reach the screws. Make sure to use a screwdriver that is thin enough to not get stuck in the screw holes.
  3. XtremeMac Luna Dissasembly: passo 3, imagem 1 %32 XtremeMac Luna Dissasembly: passo 3, imagem 2 %32
    • Flip the Luna back over so that the buttons are facing upward and the LCD screen is facing you.
    • Gently tilt the lid back 45 degrees so that the inside is exposed.
    • Be mindful of the wires inside of the Luna. It is easy to break a connection if a wire gets caught.
Conclusão
Daniel Johnson
Membro desde: 04/14/13
1 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 3-47, Amido Spring 2013 Membro de Cal Poly, Team 3-47, Amido Spring 2013
CPSU-AMIDO-S13S3G47
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 11
Duração total: 435
