Ir para o conteúdo principal
Xperia Play - Hard Reset / Password Removal
Vídeo de Apresentação
  1. Xperia Play - Hard Reset / Password Removal, Xperia Play - Hard Reset / Password Removal: passo 1, imagem 1 %32 Xperia Play - Hard Reset / Password Removal, Xperia Play - Hard Reset / Password Removal: passo 1, imagem 2 %32 Xperia Play - Hard Reset / Password Removal, Xperia Play - Hard Reset / Password Removal: passo 1, imagem 3 %32
    • Open the Emergency call keyboard.
    • Enter this code: *#*#7378423#*#*
    • From the Service Menu select: "Customization Settings".
    i cant do that with Sony Aqua M..PLEASE HELP
    qlitia - Responder
    should I press call afterwards? no service menu pops up , it just says : call not sent not an emergency number
    Witbooi M - Responder
    Doesn't let me do anything! Help?
    Jordan Favel - Responder
    When i enter this code it says that it's not an emergency number...What to do now????
    Ansh Vardhan - Responder
    Same problem .not emergency number ?..?
    Mix Kewl - Responder
    thank you worked great 3 minutes
    goof slayer - Responder
    same: is not an emergency number
    reyazada - Responder
    nakalimutan ang pincode
    cristilyn.reyes - Responder
    bonjour j’ai prêté mon tel et la personne à mis un MDP, maintenant je suis complètement bloque, impossible de rentrer dans le tel si je ne rentre pas le mdp
    Ghislaine Beber - Responder
    J'ai taper le code et cela ne fonctionne pas ..
    Marine Bideau - Responder
    Nonsense, not working
    Shahieda Isaacs - Responder
  2. Xperia Play - Hard Reset / Password Removal: passo 2, imagem 1 %32 Xperia Play - Hard Reset / Password Removal: passo 2, imagem 2 %32 Xperia Play - Hard Reset / Password Removal: passo 2, imagem 3 %32
    • Select "Reset customization" and "Reset customization and reboot".
    • The Android system will erase all personal information and will reboot the phone to the original factory settings.
    Thank you so much I found one of many of  my Daughters old mobiles but she couldn't remember any passwords to unlock the phone thanks to your information I have been able to unlock the phone and had the best surprise ever some wonderful photos of  1 of our horses and 1 of our dogs who are in pet heaven and photos of my Dad’s 80th birthday celebrations a few years ago with all the family these are so special as my Father my Hero passed away recently so to see his happy smiling face looking at me melts my heart.
    Thank you
    Tracy - Responder
    I tried to follow the above process. after entering the code in emergency call mode, when I tried to press the call button the screen reflects a message “this is not an emergency number. hence call not forwarded”
    ksnmurty - Responder
  3. Xperia Play - Hard Reset / Password Removal: passo 3, imagem 1 %32
    • Did you do it successfully?
    my phone is nt taking *#*#7378423#*#* says it's nt an emergency number
    sphelelexulu - Responder
    this suckss....it cant even work on sony xperia m aqua
    qlitia - Responder
    Hi my phone says the same what do i do
    tamara pryor - Responder
    My phone does the same as everyone elses, its my old phone but as my pne is broken i need to now use this phone for awhile, just cant remember the pin for the life of me, anything else i can do please, thank you.
    kelly - Responder
    no. I tried to follow the above process. after entering the code in emergency call mode, when I tried to press the call button the screen reflects a message “this is not an emergency number. hence call not forwarded”. If there is a way out please suggest the same. thank you
    Dude, It Goes Till Customization Sttings and The Goes to Reset customisation and then returns back to the same lock screen
    Rohan Suresh - Responder
    its dosnt work …..
    bachalebchir - Responder
Conclusão
99 outras pessoas executaram este guia.
ZFix
Membro desde: 12/09/13
191.308 Reputação
Autoria de 330 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 322
Autoria de 2.535 guias
48 comentários
I didn't get the Customization Settings option. i just got "Service info", "service settings", and "Service tests"
kennynguyen0829 - Responder
There is no customization settings option so how do we reset ????
roy7ster - Responder
Because of high Android version.You have to reflash it with Sony PC Companion:
Factory Reset, Fix Android Problems with Sony PC Companion
Regards.
ZFix -
I did it! Thank you, i was able to unlock it and all my pictures and music are still there! :)
Miri - Responder
Ahhh great I made it thanks
tkmuparadzi - Responder
Many thanks for a great fix......worked first time . My biggest problem was lack of memory for the password. Senior moments again. Ta.ta
mcmen - Responder
I did it correctly and still wanted the pattern to reset phone....help
Kenny Vorhees - Responder
What is the error message says? You can read this article to unlock the password without losing any data: http://bit.ly/28Xsybd
kersonzine -
I have two Sony xperia phones non of them will hard reset.
Subzero - Responder
its not working for me. I enter in the code in the emergency call but nothing happens.
Tim Hudson - Responder
Not for me either
joelholmstrom -
Tim did you get a reply?im having the same issue?I need my pho.e desperately..
Serena vega -
what should do after *#*#7378423#*#*
if am calling than told that it is not an emergency number
mukesh - Responder
Did you ever get passed this step?
nicholekeepsmiling -
I keep getting same
Elaine Barker -
Ohhh.. i was soo tensed on what to do now.. and that Code allowed me to go to settings and start the wifi through which i could enter my username and password and unlock it. THanks a lot for this video
Smilu - Responder
Hi ..i tried to use the code given but still can't reset my phone ...due to forget my patern lock. Is there any other ways i can unlock?
tamtader - Responder
How to unlock forgotten pass code from Sony xperia pm -0160-bv ?
asnajeeb - Responder
My top half of my screen is cracked so I can't touch the three
Ayla - Responder
I know my lock screen password but i cant remove it from setting-security becose my none option in security is disabled by administration, encryption policy or credential storage. So what can i do now please sugest.
akshay kore - Responder
The only thing mine says is service info service setting and service tests
Irma gomez - Responder
My phone only says service info service settings service test and that's all what Do I do
maraming salamat po..val patelo.. luzon av.quezon city
bobby - Responder
maraming salamat po..frm val patelo LUZON AVE QC
bobby - Responder
I have 1.7 years old Panasonic Eluga I Android phone. It was misplaced so I remotely erased through Gmail Account. Now I have found it. When I power it on then only WELCOME screen appears with emergency dialing pad and nothing else.
When I tried hard reset by Vol Key up and down with power button then Factory Reset screen pops up and no other option is working so that I can proceed ahead. What to do next. I am in great need. Please help me out.
Ramsharan Kumar - Responder
My phone says this is not an emergency number
Jaime Lewis - Responder
For the phones with newer Android OS you have to use Sony PC Companion:
ZFix -
people help me i'm using a sony experia model E2105 the hard resert service does not work on my phone
tiegodelay8 - Responder
I can see the customization settings. Please I need directions
Raphael Blackie - Responder
I can't see the customization settings plz
Hi mine says you cant make a call
mine didn't go through is there any other method of unlocking it
Aganyi peter - Responder
i forget my sony xep xz pin now my mobile lock how to i unlock or reset my phone
please help me
jeish - Responder
hey I have sony x10i I just can"t find customisation option I only see three things viz
1.service info
2.service settings
3.service test
please help............
ayanda mveli - Responder
thx alot, i lost this phone 3 years ago , and now i forgot my pattern, AND THANK YOU
Justas Tamošiūnas - Responder
I can’t turn on my Xperia play. :( help
cat zeta jones - Responder
Sony d213 full ricovre
Ajay Dongre - Responder
plzz help me my password is forgot sony xperia m9+
ejhay - Responder
Please I can't dlfind customer reboot on my phone is only service info,service settings, and service tests…..please help me out I beg you
Yeboah Qwabena Matthew - Responder
hi. i entered *#*#7378423#*#* on emergecy keyborad, but every time i completed it, the keyboard kicked me out, and i had to enter the code again, but keyboard kicked ,e out again, ad again, and again, what i should do??
matěj Hlinka - Responder
I'm not getting the setting option on the emergency dialer after I put in the reset code. What do I do?
Mellisa Pillay - Responder
Merci beaucoup sa été une bonne aide
Karine Allison - Responder
Merci d'aider les gens comme nous
J'ai mon téléphone reinitialisation au parametre d'usine mais je sais pas comment avoir le mot de passe pour accéder au téléphone
Océane Cangina - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 22
Últimos 7 dias: 105
Últimos 30 dias: 433
Duração total: 438,438
