Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
The motherboard that houses the micro-usb and HDMI connection may become damaged. This guide will help the user in replacing a corrupt motherboard.
O que você precisa
Introduce the plastic opening tool into any of the sides of the camera.
Pry with the plastic opening tool at the seam between the front and the back panel.
Remove the four 3.8 mm Phillips #000 screws located in the outer corners of the motherboard.
Remove the two 3.1 mm Phillips #000 screws securing the motherboard to the chassis.
11 outras pessoas executaram este guia.
8 comentários
Where you buy motherboard for xiaomi yi ?
Link for buying it waaaaaaaay cheaper:http://bit.ly/XiaoMiYi1080P
Great guide but useless, there is no spare parts on the market for this camera
IC repair is always possible
AdamA -
