Ir para o conteúdo principal
Xiaomi Yi Motherboard Replacement
O que você precisa
  1. Xiaomi Yi Motherboard Replacement, Battery: passo 1, imagem 1 %32 Xiaomi Yi Motherboard Replacement, Battery: passo 1, imagem 2 %32
    • Push the battery door switch to the left.
    • Lift the battery door up.
  2. Xiaomi Yi Motherboard Replacement: passo 2, imagem 1 %32 Xiaomi Yi Motherboard Replacement: passo 2, imagem 2 %32 Xiaomi Yi Motherboard Replacement: passo 2, imagem 3 %32
    • Lift the battery tab up.
    • Remove the battery by pulling the removal tab.
  3. Xiaomi Yi Motherboard Replacement, Front Panel: passo 3, imagem 1 %32 Xiaomi Yi Motherboard Replacement, Front Panel: passo 3, imagem 2 %32
    • Introduce the plastic opening tool into any of the sides of the camera.
    • Pry with the plastic opening tool at the seam between the front and the back panel.
  4. Xiaomi Yi Motherboard Replacement: passo 4, imagem 1 %32 Xiaomi Yi Motherboard Replacement: passo 4, imagem 2 %32 Xiaomi Yi Motherboard Replacement: passo 4, imagem 3 %32
    • Slide prying tool along the seam until front panel is fully separated from the back panel.
  5. Xiaomi Yi Motherboard Replacement, Back Panel: passo 5, imagem 1 %32 Xiaomi Yi Motherboard Replacement, Back Panel: passo 5, imagem 2 %32
    • Remove the four 3.8 mm Phillips #000 screws located in the outer corners of the motherboard.
  6. Xiaomi Yi Motherboard Replacement: passo 6, imagem 1 %32 Xiaomi Yi Motherboard Replacement: passo 6, imagem 2 %32 Xiaomi Yi Motherboard Replacement: passo 6, imagem 3 %32
    • Pull on and remove the black spacer located at the top inside of the camera body using the tweezers and set the part aside.
  7. Xiaomi Yi Motherboard Replacement: passo 7, imagem 1 %32 Xiaomi Yi Motherboard Replacement: passo 7, imagem 2 %32
    • Remove the motherboard from from the back case by gently pulling on the lens housing.
    • Back panel remains.
  8. Xiaomi Yi Motherboard Replacement, Motherboard: passo 8, imagem 1 %32 Xiaomi Yi Motherboard Replacement, Motherboard: passo 8, imagem 2 %32
    • Remove the two 3.1 mm Phillips #000 screws securing the motherboard to the chassis.
    • Be sure to support the motherboard, the ribbon cable connection can easily be damaged.
  9. Xiaomi Yi Motherboard Replacement: passo 9, imagem 1 %32 Xiaomi Yi Motherboard Replacement: passo 9, imagem 2 %32 Xiaomi Yi Motherboard Replacement: passo 9, imagem 3 %32
    • Locate the rubber spacer between the image sensor and the ribbon connection for the motherboard.
    • Using the tweezers gently remove the spacer block and set aside.
  10. Xiaomi Yi Motherboard Replacement: passo 10, imagem 1 %32 Xiaomi Yi Motherboard Replacement: passo 10, imagem 2 %32
    • Pry gently using the flat end of the black spudger to remove the ribbon connector.
    • Lift the lens assembly up and away from the motherboard.
    • Motherboard remains.
Conclusão
11 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 15-5, Blackwell Fall 2015 Membro de USF Tampa, Team 15-5, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G5
Membros da 3
Autoria de 10 guias
8 comentários
Where you buy motherboard for xiaomi yi ?
diamond1981 - Responder
I wonder where I can buy this part ribbon connector to buy.
viilelaa - Responder
Link for buying it waaaaaaaay cheaper:http://bit.ly/XiaoMiYi1080P
tozilen - Responder
Great guide but useless, there is no spare parts on the market for this camera
Nebojsa Rosic - Responder
IC repair is always possible
AdamA -
Has someone found where to buy spare parts? Or damaged camera?
Toni - Responder
Any idea where I could buy parts for this camera? Has anyone managed to find any parts on the market?
Lothar Krupka - Responder
where is ic power ??
Hafiz Darsy - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 17
Duração total: 12,232
