Ir para o conteúdo principal
Introdução
The motherboard that houses the micro-usb and HDMI connection may become damaged. This guide will help the user in replacing a corrupt motherboard.
Peças
Nenhum componente especificado.
  1. Push the battery door switch to the left. Lift the battery door up.
    • Push the battery door switch to the left.
    • Lift the battery door up.
  2. Lift the battery tab up. Remove the battery by pulling the removal tab. Remove the battery by pulling the removal tab.
    • Lift the battery tab up.
    • Remove the battery by pulling the removal tab.
  3. Introduce the plastic opening tool into any of the sides of the camera. Pry with the plastic opening tool at the seam between the front and the back panel.
    • Introduce the plastic opening tool into any of the sides of the camera.
    • Pry with the plastic opening tool at the seam between the front and the back panel.
  4. Slide  prying tool along the seam until front panel is fully separated from the back panel. Slide  prying tool along the seam until front panel is fully separated from the back panel. Slide  prying tool along the seam until front panel is fully separated from the back panel.
    • Slide prying tool along the seam until front panel is fully separated from the back panel.
  5. Remove the four 3.8 mm Phillips #000 screws located in the outer corners of the motherboard. Remove the four 3.8 mm Phillips #000 screws located in the outer corners of the motherboard.
    • Remove the four 3.8 mm Phillips #000 screws located in the outer corners of the motherboard.
  6. Pull on and remove the black spacer located at the top inside of the camera body using the tweezers and set the part aside. Pull on and remove the black spacer located at the top inside of the camera body using the tweezers and set the part aside. Pull on and remove the black spacer located at the top inside of the camera body using the tweezers and set the part aside.
    • Pull on and remove the black spacer located at the top inside of the camera body using the tweezers and set the part aside.
  7. Remove the motherboard from from the back case by gently pulling on the lens housing. Back panel remains.
    • Remove the motherboard from from the back case by gently pulling on the lens housing.
    • Back panel remains.
  8. Remove the two 3.1 mm Phillips #000 screws securing the motherboard to the chassis. Be sure to support the motherboard, the ribbon cable connection can easily be damaged.
    • Remove the two 3.1 mm Phillips #000 screws securing the motherboard to the chassis.
    • Be sure to support the motherboard, the ribbon cable connection can easily be damaged.
  9. Locate the rubber spacer between the image sensor and the ribbon connection for the motherboard. Using the tweezers gently remove the spacer block and set aside. Using the tweezers gently remove the spacer block and set aside.
    • Locate the rubber spacer between the image sensor and the ribbon connection for the motherboard.
    • Using the tweezers gently remove the spacer block and set aside.
  10. Pry gently using the flat end of the black spudger to remove the ribbon connector. Lift the lens assembly up and away from the motherboard.
    • Pry gently using the flat end of the black spudger to remove the ribbon connector.
    • Lift the lens assembly up and away from the motherboard.
    • Motherboard remains.
Conclusão
10 outras pessoas concluíram este guia.
William Zipperer
Membro desde: 03/09/2015
663 Reputação
3 Guias de autoria
Equipe
USF Tampa, Team 15-5, Blackwell Fall 2015 Membro de USF Tampa, Team 15-5, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G5
3 Membros
10 Guias de autoria
Where you buy motherboard for xiaomi yi ?
diamond1981 - Responder
I wonder where I can buy this part ribbon connector to buy.
viilelaa - Responder
Link for buying it waaaaaaaay cheaper:http://bit.ly/XiaoMiYi1080P
tozilen - Responder
Great guide but useless, there is no spare parts on the market for this camera
Nebojsa Rosic - Responder
IC repair is always possible
AdamA -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 38
Duração total: 11,326
