Ir para o conteúdo principal
Xiaomi Yi Front Panel Replacement
O que você precisa
  1. Xiaomi Yi Front Panel Replacement, Battery: passo 1, imagem 1 %32 Xiaomi Yi Front Panel Replacement, Battery: passo 1, imagem 2 %32
    • Push the battery door switch to the left.
    • Lift the battery door up.
  2. Xiaomi Yi Front Panel Replacement: passo 2, imagem 1 %32 Xiaomi Yi Front Panel Replacement: passo 2, imagem 2 %32 Xiaomi Yi Front Panel Replacement: passo 2, imagem 3 %32
    • Lift the battery tab up.
    • Remove the battery by pulling the removal tab.
  3. Xiaomi Yi Front Panel Replacement, Front Panel: passo 3, imagem 1 %32 Xiaomi Yi Front Panel Replacement, Front Panel: passo 3, imagem 2 %32
    • Introduce the plastic opening tool into any of the sides of the camera.
    • Pry with the plastic opening tool at the seam between the front and the back panel.
  4. Xiaomi Yi Front Panel Replacement: passo 4, imagem 1 %32 Xiaomi Yi Front Panel Replacement: passo 4, imagem 2 %32 Xiaomi Yi Front Panel Replacement: passo 4, imagem 3 %32
    • Slide prying tool along the seam until front panel is fully separated from the back panel.
Conclusão
5 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 15-5, Blackwell Fall 2015 Membro de USF Tampa, Team 15-5, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G5
Membros da 3
Autoria de 10 guias
3 comentários
Where do you get a spare front panel, the small plastic hooks break easily
ltkipras - Responder
I would like to know too because i had a crash and i lost the ring that goes around the lens.
fabiocastroam -
For what is the black Strip with the gold plated contact on the front panel? Is that a check for installated front panel, and can i fake them for an replacement panel?
shguro - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 2,808
