Introdução
The front panel is attached to the main case of the camera. It can be removed with a small blue plastic opening tool.
The front panel does not include the lens, but does allow you access to other internal parts of the camera; or, to replace a damaged front panel.
Ferramentas
Peças
Nenhum componente especificado.
Introduce the plastic opening tool into any of the sides of the camera.
Pry with the plastic opening tool at the seam between the front and the back panel.
5 outras pessoas concluíram este guia.
3 comentários
I would like to know too because i had a crash and i lost the ring that goes around the lens.
