Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Push the battery door switch to the left.
Lift the battery door up.
Lift the battery tab up.
Remove the battery by pulling the removal tab.
Introduce the plastic opening tool into any of the sides of the camera.
Pry with the plastic opening tool at the seam between the front and the back panel.
Slide prying tool along the seam until front panel is fully separated from the back panel.
Remove the four 3.8 mm Phillips #000 screws located in the outer corners of the motherboard.
Pull on and remove the black spacer located at the top inside of the camera body using the tweezers and set the part aside.
Remove the motherboard from from the back case by gently pulling on the lens housing.
Back panel remains.
10 outras pessoas executaram este guia.
2 comentários
Where can i buy the back panel replacement ?
