Ir para o conteúdo principal
Xiaomi Yi Back Panel Replacement
O que você precisa
  1. Xiaomi Yi Back Panel Replacement, Battery: passo 1, imagem 1 %32 Xiaomi Yi Back Panel Replacement, Battery: passo 1, imagem 2 %32
    • Push the battery door switch to the left.
    • Lift the battery door up.
  2. Xiaomi Yi Back Panel Replacement: passo 2, imagem 1 %32 Xiaomi Yi Back Panel Replacement: passo 2, imagem 2 %32 Xiaomi Yi Back Panel Replacement: passo 2, imagem 3 %32
    • Lift the battery tab up.
    • Remove the battery by pulling the removal tab.
  3. Xiaomi Yi Back Panel Replacement, Front Panel: passo 3, imagem 1 %32 Xiaomi Yi Back Panel Replacement, Front Panel: passo 3, imagem 2 %32
    • Introduce the plastic opening tool into any of the sides of the camera.
    • Pry with the plastic opening tool at the seam between the front and the back panel.
  4. Xiaomi Yi Back Panel Replacement: passo 4, imagem 1 %32 Xiaomi Yi Back Panel Replacement: passo 4, imagem 2 %32 Xiaomi Yi Back Panel Replacement: passo 4, imagem 3 %32
    • Slide prying tool along the seam until front panel is fully separated from the back panel.
  5. Xiaomi Yi Back Panel Replacement, Back Panel: passo 5, imagem 1 %32 Xiaomi Yi Back Panel Replacement, Back Panel: passo 5, imagem 2 %32
    • Remove the four 3.8 mm Phillips #000 screws located in the outer corners of the motherboard.
  6. Xiaomi Yi Back Panel Replacement: passo 6, imagem 1 %32 Xiaomi Yi Back Panel Replacement: passo 6, imagem 2 %32 Xiaomi Yi Back Panel Replacement: passo 6, imagem 3 %32
    • Pull on and remove the black spacer located at the top inside of the camera body using the tweezers and set the part aside.
  7. Xiaomi Yi Back Panel Replacement: passo 7, imagem 1 %32 Xiaomi Yi Back Panel Replacement: passo 7, imagem 2 %32
    • Remove the motherboard from from the back case by gently pulling on the lens housing.
    • Back panel remains.
Conclusão
10 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 15-5, Blackwell Fall 2015 Membro de USF Tampa, Team 15-5, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G5
Membros da 3
Autoria de 10 guias
2 comentários
Where can I buy back panel for Xiaomi Yi?
matulek - Responder
Where can i buy the back panel replacement ?
Roland Meilleur - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 11
Duração total: 3,544
