Ir para o conteúdo principal
Xiaomi Redmi Note Rear Camera Replacement
O que você precisa
  1. Xiaomi Redmi Note Rear Camera Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the Xiaomi Redmi Note is powered off before removing the battery.
    • Insert the plastic opening tool between the charging port and the rear case.
    • Pry the end of the rear case up from the charging port.
  2. Xiaomi Redmi Note Rear Camera Replacement: passo 2, imagem 1 %32 Xiaomi Redmi Note Rear Camera Replacement: passo 2, imagem 2 %32
    • Run the plastic opening tool along the seam on the side of the phone to remove the rear casing.
  3. Xiaomi Redmi Note Rear Camera Replacement: passo 3, imagem 1 %32 Xiaomi Redmi Note Rear Camera Replacement: passo 3, imagem 2 %32
    • Locate the indentation at the bottom of the battery.
    • Place a finger in the indentation and lift up to remove the battery.
  4. Xiaomi Redmi Note Rear Camera Replacement, Midframe: passo 4, imagem 1 %32 Xiaomi Redmi Note Rear Camera Replacement, Midframe: passo 4, imagem 2 %32
    • Remove twelve 3.5mm Phillips #00 screws from the midframe.
  5. Xiaomi Redmi Note Rear Camera Replacement: passo 5, imagem 1 %32 Xiaomi Redmi Note Rear Camera Replacement: passo 5, imagem 2 %32
    • Insert a plastic opening into the seam between the midframe and the bottom frame of the phone.
    • Run the plastic opening tool along the seam.
    • Pry up the midframe with the plastic opening tool.
    • Once the midframe has been sufficiently lifted with the tool, place a hand underneath the edge to lift the entire component out of the frame.
    • There will be snapping sounds as the clips on the midframe disconnect from the phone.
  6. Xiaomi Redmi Note Rear Camera Replacement, Rear Camera: passo 6, imagem 1 %32 Xiaomi Redmi Note Rear Camera Replacement, Rear Camera: passo 6, imagem 2 %32
    • Disconnect the rear-facing camera from the motherboard by pulling out the press-fit connector to its left.
Conclusão
4 outras pessoas executaram este guia.
AJ Beers
Membro desde: 04/26/17
213 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S22-G4, Livingston Spring 2017 Membro de Cal Poly, Team S22-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G4
Membros da 4
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 10
Últimos 30 dias: 33
Duração total: 3,631
