Introdução
This guide will show you how to replace the connector between your charging cable and your phone. Replacing this component may be useful if your phone's charging port can no longer make a solid connection with your charging cable due to damage or debris.
O que você precisa
Insert the plastic opening tool between the charging port and the rear case.
Pry the end of the rear case up from the charging port.
Insert a plastic opening into the seam between the midframe and the bottom frame of the phone.
Run the plastic opening tool along the seam.
Pry up the midframe with the plastic opening tool.
Once the midframe has been sufficiently lifted with the tool, place a hand underneath the edge to lift the entire component out of the frame.
Locate the charging port panel at the bottom of the device.
Remove the 2.9 mm Phillips #00 screws on the sides of the panel.
23 outras pessoas executaram este guia.
9 comentários
Hi, should the battery have a certain time of charge after replacement? Or just start using like everyday, charge when needed?
Hi Caitlin, do you know where I can purchase an OEM Charging Port? All I can find is non OEM parts on eBay and parts on witrig. I looked into that site, and it has awful reviews, so I’m not going to try it.
hi where can i buy the replacement port charger for the xioami note boo pease
View similar itemsItem - Xiaomi Mi Pad 3 Tablet PC 7.9'' MIUI 8 2.1GHz MT8176 Hexa Core 4GB+64GB WiFi
