Ir para o conteúdo principal
Xiaomi Redmi Note Charging Port Replacement
O que você precisa
  1. Xiaomi Redmi Note Charging Port Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the Xiaomi Redmi Note is powered off before removing the battery.
    • Insert the plastic opening tool between the charging port and the rear case.
    • Pry the end of the rear case up from the charging port.
    Pergunte ao FixBot
    Comentar
  2. Xiaomi Redmi Note Charging Port Replacement: passo 2, imagem 1 %32 Xiaomi Redmi Note Charging Port Replacement: passo 2, imagem 2 %32
    • Run the plastic opening tool along the seam on the side of the phone to remove the rear casing.
    Pergunte ao FixBot
    Comentar
  3. Xiaomi Redmi Note Charging Port Replacement: passo 3, imagem 1 %32 Xiaomi Redmi Note Charging Port Replacement: passo 3, imagem 2 %32
    • Locate the indentation at the bottom of the battery.
    • Place a finger in the indentation and lift up to remove the battery.
    Pergunte ao FixBot
    Comentar
  4. Xiaomi Redmi Note Charging Port Replacement, Midframe: passo 4, imagem 1 %32 Xiaomi Redmi Note Charging Port Replacement, Midframe: passo 4, imagem 2 %32
    • Remove twelve 3.5mm Phillips #00 screws from the midframe.
    Pergunte ao FixBot
    Comentar
  5. Xiaomi Redmi Note Charging Port Replacement: passo 5, imagem 1 %32 Xiaomi Redmi Note Charging Port Replacement: passo 5, imagem 2 %32
    • Insert a plastic opening into the seam between the midframe and the bottom frame of the phone.
    • Run the plastic opening tool along the seam.
    • Pry up the midframe with the plastic opening tool.
    • Once the midframe has been sufficiently lifted with the tool, place a hand underneath the edge to lift the entire component out of the frame.
    • There will be snapping sounds as the clips on the midframe disconnect from the phone.
    Pergunte ao FixBot
    Comentar
  6. Xiaomi Redmi Note Charging Port Replacement, Charging Port: passo 6, imagem 1 %32 Xiaomi Redmi Note Charging Port Replacement, Charging Port: passo 6, imagem 2 %32
    • Locate the charging port panel at the bottom of the device.
    • Remove the 2.9 mm Phillips #00 screws on the sides of the panel.
    Pergunte ao FixBot
    Comentar
  7. Xiaomi Redmi Note Charging Port Replacement: passo 7, imagem 1 %32 Xiaomi Redmi Note Charging Port Replacement: passo 7, imagem 2 %32 Xiaomi Redmi Note Charging Port Replacement: passo 7, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Locate the antenna cable at the top right corner of the charging port.
    • Lift the antenna cable off of the panel with tweezers.
    Pergunte ao FixBot
    Comentar
  8. Xiaomi Redmi Note Charging Port Replacement: passo 8, imagem 1 %32 Xiaomi Redmi Note Charging Port Replacement: passo 8, imagem 2 %32 Xiaomi Redmi Note Charging Port Replacement: passo 8, imagem 3 %32
    • Flip the panel to its back side, but do not fully lift it off of the phone yet.
    • Use a plastic opening tool to gently pry off the press fit connector attached to the back side of the panel.
    Pergunte ao FixBot
    Comentar
  9. Xiaomi Redmi Note Charging Port Replacement: passo 9, imagem 1 %32
    • Lift the charging port up to remove it from the frame.
    Pergunte ao FixBot
    Comentar
Conclusão
26 outras pessoas executaram este guia.
Equipe
Cal Poly, Team S22-G4, Livingston Spring 2017 Membro de Cal Poly, Team S22-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G4
4 Membros
Autoria de 16 guias
9Comentários do guia
Hi, should the battery have a certain time of charge after replacement? Or just start using like everyday, charge when needed?
Luis Amaral - Responder Compartilhar
Hi Caitlin, do you know where I can purchase an OEM Charging Port? All I can find is non OEM parts on eBay and parts on witrig. I looked into that site, and it has awful reviews, so I’m not going to try it.
ilikechocobo - Responder Compartilhar
hi where can i buy the replacement port charger for the xioami note boo pease
View similar itemsItem - Xiaomi Mi Pad 3 Tablet PC 7.9'' MIUI 8 2.1GHz MT8176 Hexa Core 4GB+64GB WiFi
Brigitte Berkaine-Tongue - Responder Compartilhar
How much is it to repair in Qatar riyal
Cynthia - Responder Compartilhar
How much does it cost to repair the charging port in Qatar royals?
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 43
Últimos 30 dias: 222
Ao todo: 42,784
