Ir para o conteúdo principal
Xiaomi Redmi Note 4X Battery Replacement
O que você precisa
  1. Xiaomi Redmi Note 4X Battery Replacement, Removing the back cover: passo 1, imagem 1 %32 Xiaomi Redmi Note 4X Battery Replacement, Removing the back cover: passo 1, imagem 2 %32 Xiaomi Redmi Note 4X Battery Replacement, Removing the back cover: passo 1, imagem 3 %32
    • The first thing we have to do is use a pry tool to remove the back cover (make sure to remove the sim tray first)
  2. Xiaomi Redmi Note 4X Battery Replacement, Removing the Battery: passo 2, imagem 1 %32 Xiaomi Redmi Note 4X Battery Replacement, Removing the Battery: passo 2, imagem 2 %32 Xiaomi Redmi Note 4X Battery Replacement, Removing the Battery: passo 2, imagem 3 %32
    • Now we have to remove the battery, luckily the Battery can be removed first after taking the back cover off.
  3. Xiaomi Redmi Note 4X Battery Replacement, Reassembly: passo 3, imagem 1 %32 Xiaomi Redmi Note 4X Battery Replacement, Reassembly: passo 3, imagem 2 %32
    • Now you can insert your new battery, pop the back cover on, and your good to go! Congratulations, you've just replaced your phone's battery.
Conclusão
Congratulations on repairing your smartphone!
Isaiah Kochis
Membro desde: 09/02/20
235 Reputação
Autoria de 2 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 24
Últimos 30 dias: 89
Ao todo: 4,273
