Introdução
Use this guide to remove the PCB circuit board in your Xiaomi Redmi 2 for repair or replacement.
O que você precisa
Use the flat end of the spudger to remove the back panel from the mid-frame and front body.
Remove the 2.9 mm Phillips #000 screw that holds the PCB circuit board to the screen assembly.
14 outras pessoas executaram este guia.
3 comentários
my phone is head phone signal
I want purches PCB Circuit not available in Akola service center
