Ir para o conteúdo principal
Xiaomi Redmi 2 Motherboard Replacement
O que você precisa
  1. Xiaomi Redmi 2 Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 Xiaomi Redmi 2 Motherboard Replacement, Motherboard: passo 1, imagem 2 %32
    • Use the flat end of the spudger to remove the back panel from the mid-frame and front body.
  2. Xiaomi Redmi 2 Motherboard Replacement: passo 2, imagem 1 %32
    • Insert your finger into the curved opening of the mid-frame.
    • Lift the battery and remove.
  3. Xiaomi Redmi 2 Motherboard Replacement: passo 3, imagem 1 %32
    • Remove the SIM and/or memory cards if present.
    • Remove twelve 3.4 mm Phillips #000 screws securing the mid-frame to the front body.
  4. Xiaomi Redmi 2 Motherboard Replacement: passo 4, imagem 1 %32
    • Slide the spudger between the mid-frame and front body, gradually prying the two bodies apart as you slide the spudger around the perimeter of the phone.
  5. Xiaomi Redmi 2 Motherboard Replacement: passo 5, imagem 1 %32
    • Remove the 3.4 mm Phillips #000 screw that holds the motherboard to the front body.
    • Keep this screw separate from the initial twelve.
  6. Xiaomi Redmi 2 Motherboard Replacement: passo 6, imagem 1 %32 Xiaomi Redmi 2 Motherboard Replacement: passo 6, imagem 2 %32
    • Using one prong of the tweezers, pry back the brown clip located on top of the LCD ribbon connector.
  7. Xiaomi Redmi 2 Motherboard Replacement: passo 7, imagem 1 %32 Xiaomi Redmi 2 Motherboard Replacement: passo 7, imagem 2 %32
    • Using one prong of the tweezers, pry the ribbon clip away from the motherboard.
  8. Xiaomi Redmi 2 Motherboard Replacement: passo 8, imagem 1 %32 Xiaomi Redmi 2 Motherboard Replacement: passo 8, imagem 2 %32
    • Lift and hinge the motherboard with your fingers.
  9. Xiaomi Redmi 2 Motherboard Replacement: passo 9, imagem 1 %32 Xiaomi Redmi 2 Motherboard Replacement: passo 9, imagem 2 %32
    • Using one prong of the tweezers, lift and pry back the metal clip positioned over the front proximity sensor ribbon connector.
  10. Xiaomi Redmi 2 Motherboard Replacement: passo 10, imagem 1 %32 Xiaomi Redmi 2 Motherboard Replacement: passo 10, imagem 2 %32
    • Using the tweezers, pull the antenna connector from the motherboard.
  11. Xiaomi Redmi 2 Motherboard Replacement: passo 11, imagem 1 %32
    • Lift the motherboard out of the front cover and set aside.
Conclusão
46 outras pessoas executaram este guia.
Alicia Brenner
Membro desde: 10/01/15
3.539 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 1-3, Leahy Fall 2015 Membro de USF Tampa, Team 1-3, Leahy Fall 2015
USFT-LEAHY-F15S1G3
Membros da 2
Autoria de 5 guias
17 comentários
this is very helpful
Ana - Responder
hi brother mi phone was water damaged .it was not wrking i mean phone gets on but no display. phone gets ring and i can lift call and speak. when i connect to laptop i can access files in it. its get charging on connecting to charger
can u suggest me wat to do
please
asreefbashak - Responder
may be LCD is damage. can fix it at 82877181 contact Peter for checking.
netman91 -
Hi bro I'm having redmi 2 mobile and it has a problem it is not taking any os it's having a compliant of not receiving os .....
There is any solution for that
Please give me reply bro any suggestions
jhon Carter - Responder
Can i know the name of the motherboard used for redmi 2 prime 16GB,please tell me the name bro
Jakka Akhilesh - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 34,981
