Ir para o conteúdo principal
Xiaomi Redmi 2 Front Speaker Replacement
O que você precisa
  1. Xiaomi Redmi 2 Front Speaker Replacement, Motherboard: passo 1, imagem 1 %32 Xiaomi Redmi 2 Front Speaker Replacement, Motherboard: passo 1, imagem 2 %32
    • Use the flat end of the spudger to remove the back panel from the mid-frame and front body.
  2. Xiaomi Redmi 2 Front Speaker Replacement: passo 2, imagem 1 %32
    • Insert your finger into the curved opening of the mid-frame.
    • Lift the battery and remove.
  3. Xiaomi Redmi 2 Front Speaker Replacement: passo 3, imagem 1 %32
    • Remove the SIM and/or memory cards if present.
    • Remove twelve 3.4 mm Phillips #000 screws securing the mid-frame to the front body.
  4. Xiaomi Redmi 2 Front Speaker Replacement: passo 4, imagem 1 %32
    • Slide the spudger between the mid-frame and front body, gradually prying the two bodies apart as you slide the spudger around the perimeter of the phone.
  5. Xiaomi Redmi 2 Front Speaker Replacement: passo 5, imagem 1 %32
    • Remove the 3.4 mm Phillips #000 screw that holds the motherboard to the front body.
    • Keep this screw separate from the initial twelve.
  6. Xiaomi Redmi 2 Front Speaker Replacement: passo 6, imagem 1 %32 Xiaomi Redmi 2 Front Speaker Replacement: passo 6, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using one prong of the tweezers, pry back the brown clip located on top of the LCD ribbon connector.
  7. Xiaomi Redmi 2 Front Speaker Replacement: passo 7, imagem 1 %32 Xiaomi Redmi 2 Front Speaker Replacement: passo 7, imagem 2 %32
    • Using one prong of the tweezers, pry the ribbon clip away from the motherboard.
  8. Xiaomi Redmi 2 Front Speaker Replacement: passo 8, imagem 1 %32 Xiaomi Redmi 2 Front Speaker Replacement: passo 8, imagem 2 %32
    • Lift and hinge the motherboard with your fingers.
  9. Xiaomi Redmi 2 Front Speaker Replacement: passo 9, imagem 1 %32 Xiaomi Redmi 2 Front Speaker Replacement: passo 9, imagem 2 %32
    • Using one prong of the tweezers, lift and pry back the metal clip positioned over the front proximity sensor ribbon connector.
  10. Xiaomi Redmi 2 Front Speaker Replacement: passo 10, imagem 1 %32 Xiaomi Redmi 2 Front Speaker Replacement: passo 10, imagem 2 %32
    • Using the tweezers, pull the antenna connector from the motherboard.
  11. Xiaomi Redmi 2 Front Speaker Replacement: passo 11, imagem 1 %32
    • Lift the motherboard out of the front cover and set aside.
  12. Xiaomi Redmi 2 Front Speaker Replacement, Front Speaker: passo 12, imagem 1 %32
    • Using the nylon or metal spudger, gently pry the front speaker from the screen assembly.
  13. Xiaomi Redmi 2 Front Speaker Replacement: passo 13, imagem 1 %32
    • Using your fingers, gently lift the front speaker from the screen assembly.
Conclusão
7 outras pessoas executaram este guia.
Alicia Brenner
Membro desde: 10/01/15
3.539 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 1-3, Leahy Fall 2015 Membro de USF Tampa, Team 1-3, Leahy Fall 2015
USFT-LEAHY-F15S1G3
Membros da 2
Autoria de 5 guias
4 comentários
How can I remove the contact from the speaker? I bought a new screen and it hasn't this contact and the vibracall module, but the second I know how to remove from the old screen.
brunofichos - Responder
sorry about my english, I want to say "back speaker's contact" not "contact from the speaker". Thanks
brunofichos -
You know how to remove the speaker contacts from the rear speaker. It's stuck in the redmi2pro frame. I bought an LCD touch frame and need to move the components to the new one.
afreitasleonardo - Responder
Rademi 2 front Speakers problem
Amol Surve - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 20
Duração total: 7,063
