Introdução
In this guide, I will show you how to replace the side-brush motor.
O que você precisa
Turn off the device by pressing and holding the power button.
Remove the main brush holder by pressing both locks inward and lifting it up.
Remove the main brush.
Remove the screw holding the side brush.
Remove the side brush along with the screw by lifting it upward.
Lift the front wheel with the screwdriver.
Completely pull the front wheel upward to remove it.
Remove the seven screws holding the bottom panel.
Lift the bottom cover up.
Remove the three screws from the motor
Pull the motor out upwards (plug connection with the circuit board)
Work through the steps in reverse order to reassemble your device.
Um agradecimento especial a esses tradutores:
100%
oldturkey03 está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
