Ir para o conteúdo principal
Xiaomi Mi Pad Rear Camera Replacement
O que você precisa
  1. Xiaomi Mi Pad Rear Camera Replacement, Rear Case Assembly: passo 1, imagem 1 %32
    • Remove the micro SD card slot from the left side of the device using either the metal pin included with the device or a SIM card eject tool.
  2. Xiaomi Mi Pad Rear Camera Replacement: passo 2, imagem 1 %32 Xiaomi Mi Pad Rear Camera Replacement: passo 2, imagem 2 %32
    • Use a plastic opening tool and/or opening pick to gently pry the back panel away from the device. Work your way around the device, slowly increasing the gap.
    • The back panel has small clips and light adhesive that easily releases from the device.
  3. Xiaomi Mi Pad Rear Camera Replacement, Rear Camera: passo 3, imagem 1 %32 Xiaomi Mi Pad Rear Camera Replacement, Rear Camera: passo 3, imagem 2 %32
    • Remove the twelve 3.0 mm Phillips #000 screws on the upper cover of the device.
  4. Xiaomi Mi Pad Rear Camera Replacement: passo 4, imagem 1 %32
    • Remove the upper cover from the device.
  5. Xiaomi Mi Pad Rear Camera Replacement: passo 5, imagem 1 %32
    • Use a plastic opening tool to disconnect the rear-facing camera from the motherboard.
  6. Xiaomi Mi Pad Rear Camera Replacement: passo 6, imagem 1 %32
    • Carefully remove the rear camera from the device.
Conclusão
Kiefer Sivitz
Membro desde: 09/03/15
560 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 12-5, Blackwell Fall 2015 Membro de USF Tampa, Team 12-5, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G5
Membros da 3
Autoria de 13 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 690
