Pular para o conteúdo principal
Introdução
Use this guide to remove the headphone jack from your Xiaomi Mi Pad.
Peças
Nenhum componente especificado.
  1. Remove the micro SD card slot from the left side of the device using either the metal pin included with the device or a SIM card eject tool.
    • Remove the micro SD card slot from the left side of the device using either the metal pin included with the device or a SIM card eject tool.
  2. Use a plastic opening tool and/or opening pick to gently pry the back panel away from the device.  Work your way around the device, slowly increasing the gap. The back panel has small clips and light adhesive that easily releases from the device.
    • Use a plastic opening tool and/or opening pick to gently pry the back panel away from the device. Work your way around the device, slowly increasing the gap.
    • The back panel has small clips and light adhesive that easily releases from the device.
  3. Remove the twelve 3.0 mm Phillips #000 screws on the upper cover of the device. Remove the twelve 3.0 mm Phillips #000 screws on the upper cover of the device.
    • Remove the twelve 3.0 mm Phillips #000 screws on the upper cover of the device.
  4. Remove the upper cover from the device.
    • Remove the upper cover from the device.
  5. Use a plastic opening tool to pull up and remove the headphone jack from the upper cover.
    • Use a plastic opening tool to pull up and remove the headphone jack from the upper cover.
    • Insert the corner of a plastic opening tool into the port of the headphone jack for easier removal.
Conclusão
Uma outra pessoa concluiu este guia.
Rene Mendoza
Membro desde: 03-09-2015
299 reputação
2 Guias de autoria
Equipe
USF Tampa, Team 12-5, Blackwell Fall 2015 Membro de USF Tampa, Team 12-5, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G5
3 Membros
12 Guias de autoria
And where to buy? :-(
marcusvoag - Responder
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Todo: 2,153
