Introdução
Use this guide to replace your Xiaomi Mi Note's screen display.
O que você precisa
Locate the hole for the Dual SIM SD card on the left side of the phone.
Use your suction cup to grip the back of the phone. Once the suction cup is secure, pull back with moderate force and the back plate should snap free.
Once the back plate is off you will need to detach the frames that hold in the battery. Locate and remove the screws (Screws are marked in the image). You can then pull the frame off with ease once the screws have been removed.
Remove the six 3.5mm Phillips #000 black screws using a securing part of the back panels.
Remove the seven 2.5mm Phillips #000 black screws securing part of the back panels.
Remove the five 2mm Phillips #000 silver screws securing the remaining back panels.
Use a spudger to detach the ribbons connected to the motherboard using an upward prying motion.
Ferramenta utilizada nesse passo:Tweezers$4.99
Use tweezers to detach the small ribbon on left side located near the volume buttons using an upwards prying motion.
You will also need to detach the microphone cord located on the right side along the frame using an upwards prying motion as well.
Apply considerable force to the back corners using your spudger to help relieve it of the adhesive as shown.
Once you have freed the screen from a portion of the adhesive, wedge your spudger around the front edge to work around the edges of the screen and frame in order to fully remove it from the frame.
20 outras pessoas executaram este guia.
3 comentários
Hello, I have unmounted my mi note pro to change the battery. I successfully changed it but now my phone's touch screen does not work anymore. The screen displays but the touch function doesn't work. Can someone help me identify the part I might have damaged or disconnected accidentally?
