Ir para o conteúdo principal
Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement
O que você precisa
  1. Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement, Screen (LCD+Touch): passo 1, imagem 1 %32 Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement, Screen (LCD+Touch): passo 1, imagem 2 %32
    • Turn off and remove the SIM card.
  2. Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement: passo 2, imagem 1 %32 Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement: passo 2, imagem 2 %32 Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement: passo 2, imagem 3 %32
    • Apply heat to loosen the back cover adhesive. Then remove it carefully.
  3. Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement: passo 3, imagem 1 %32 Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement: passo 3, imagem 2 %32
    • Remove all nine screws that hold the shield protecting the motherboard.
  4. Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement: passo 4, imagem 1 %32 Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement: passo 4, imagem 2 %32 Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement: passo 4, imagem 3 %32
    • Remove the shield and disconnect the battery connector, LCD and touch connector, and touch ID connector.
  5. Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement: passo 5, imagem 1 %32 Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement: passo 5, imagem 2 %32 Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement: passo 5, imagem 3 %32
    • Remove the battery carefully as shown and apply heat to loosen the adhesive holding the screen.
  6. Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement: passo 6, imagem 1 %32 Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement: passo 6, imagem 2 %32 Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement: passo 6, imagem 3 %32
    • Carefully start to separate the screen as shown. Start from the top corner.
  7. Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement: passo 7, imagem 1 %32 Xiaomi Mi Mix 2s Screen (LCD+Touch) Replacement: passo 7, imagem 2 %32
    • You have done it.
Conclusão
8 outras pessoas executaram este guia.
Kefelegn Derbew
Membro desde: 06/23/14
553 Reputação
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 20
Últimos 30 dias: 110
Duração total: 7,637
