Introdução
If you got a broken screen of your Xiaomi Mi Mix 2, you can follow this video to replace it. It is easy to remove the LCD screen because the original adhesive is not strong and the inner design of Mi Mix 2 is simply.
O que você precisa
Instruções em vídeo
7 outras pessoas executaram este guia.
5 comentários
Very good video tutorial. Completed today successfully I'm about 1 hour.
Thank you very much!
Lobi - Responder
Attention à ne pas oublier de retirer le tiroir de la carte SIM !
Louis BENARD - Responder
Attention aussi lorsque vous retirer les câbles d’antenne : les connectiques soudées côté carte se sont cassées lorsque j’ai débranché (avec la spatule). Je n’ai donc pas pu aller au bout de la réparation.
Where can I fix my phone I'm around Cape Town
Phumelela Magantoli - Responder
Why did you skip the part where you’re putting the new screen on??
Josef H. - Responder
