Introdução
If the battery of your Xiaomi Mi Mix 2 drys out too quick, you can follow this video to replace the battery.
O que você precisa
Instruções em vídeo
Quase terminado!
Conclusão
Um comentário
1 - I cannot see why it is necessary to remove the mainboard. It looks as if both do not disturb each other.
2 - When using double-sided adhesive tape to install the new battery the way you show it, how can you remove the battery next time? You cannot pull the tape out as before. Can’t this tape be replaced by something less annoying?
LisaLi - Responder
