Introdução
If the back cover of your Xiaomi Mi Mix 2 got shattered or damaged, you can follow this video to replace the broken battery cover. This video shows you the replacement procedure step by step.
O que você precisa
Instruções em vídeo
Quase terminado!
Conclusão
2 comentários
¿Is it the same replacement for the Mi Mix 2 SE (Special Edition) ? If it isn’t, could you provide it? Thanks you
David - Responder
I’m also interested in changing the battery of my Mi Mix 2 SE (full ceramic cover) It has two screws on the bottom, but I really don’t know if it’s possible to take out the cover just unscrewing
Pablo Sahagun - Responder
