Ir para o conteúdo principal
Xiaomi Mi A2 USB Port Replacement
O que você precisa
  1. Xiaomi Mi A2 USB Port Replacement, Screen: passo 1, imagem 1 %32 Xiaomi Mi A2 USB Port Replacement, Screen: passo 1, imagem 2 %32
    • Turn off your phone before proceeding.
    • Remove SIM card tray from phone.
    • Touch something metallic to ensure you are electrostatic safe.
  2. Xiaomi Mi A2 USB Port Replacement: passo 2, imagem 1 %32
    • Remove the two 2.7mm Pentalobe #2 screws from the bottom of the phone.
  3. Xiaomi Mi A2 USB Port Replacement: passo 3, imagem 1 %32 Xiaomi Mi A2 USB Port Replacement: passo 3, imagem 2 %32 Xiaomi Mi A2 USB Port Replacement: passo 3, imagem 3 %32
    • Grab a suction cup tool and place it near the bottom of the phone.
    • Pull up on the suction cup to slightly lift the LCD Panel from the body of the phone.
    • Starting from the bottom, slide in a plastic opening tool between the gap of the LCD and the phone.
    • Using a combination of the plastic opening tool and picks, slide around the gaps to unhook the clips, unhinging the panel from the body of the phone.
    • Flip the phone screen towards the bottom of the device and lay the screen facing down.
    • Note: The ribbon cable is in the middle of the panel, thus there is no need to be cautious about snagging a ribbon cable
  4. Xiaomi Mi A2 USB Port Replacement: passo 4, imagem 1 %32 Xiaomi Mi A2 USB Port Replacement: passo 4, imagem 2 %32
    • When removing the ribbon cable and installing the new one take special care to not bend or fold the cable too much as this can cause damage to the cable itself.
    • To access the ribbon cable connectors we must remove the metal bracket.
    • Remove the three 2.4mm Philips #0 screws that hold the panel down.
  5. Xiaomi Mi A2 USB Port Replacement: passo 5, imagem 1 %32 Xiaomi Mi A2 USB Port Replacement: passo 5, imagem 2 %32 Xiaomi Mi A2 USB Port Replacement: passo 5, imagem 3 %32
    • Using a plastic spudger remove the battery connector ribbon cable by getting underneath the connector and gently lifting it off.
    • Using a plastic sudger remove the screen connector ribbon cable by lifting from the underneath.
    • After you remove the ribbon cable the panel should be free to remove and replace.
  6. Xiaomi Mi A2 USB Port Replacement, USB Port: passo 6, imagem 1 %32 Xiaomi Mi A2 USB Port Replacement, USB Port: passo 6, imagem 2 %32
    • Remove the two 3.8mm Phillips #0 screws holding down the lower metal bracket.
  7. Xiaomi Mi A2 USB Port Replacement: passo 7, imagem 1 %32 Xiaomi Mi A2 USB Port Replacement: passo 7, imagem 2 %32
    • Remove the loud speaker. There are three 2.4mm Phillips #0 screws you need to remove, and one (upper right) is underneath the Xiaomi water sticker.
  8. Xiaomi Mi A2 USB Port Replacement: passo 8, imagem 1 %32 Xiaomi Mi A2 USB Port Replacement: passo 8, imagem 2 %32
    • Unplug the antenna wire with a spudger tool.
    • Remove another 2.4mm Phillips #0 screw near vibration motor.
  9. Xiaomi Mi A2 USB Port Replacement: passo 9, imagem 1 %32 Xiaomi Mi A2 USB Port Replacement: passo 9, imagem 2 %32
    • The ribbon cable connector is located underneath the sub-board. To access the connector flip the board over towards the battery.
    • Use a spudger tool to remove the cable from the connector.
    • The USB Connector board can now be removed from the device and replaced.
Conclusão
8 outras pessoas executaram este guia.
Erica Ko
Membro desde: 10/18/19
255 Reputação
Autoria de 1 guia
Equipe
2 comentários
Hey, I can only find those USB connector boards online where all the chips on it are missing. Does anyone know where I can find a proper replacement board?
Hnas Krack - Responder
Same problem for me. I just bought a "1:1 replacement" board, which has missing chips and does not allow data transfer. Charging was possible (only very slow). However, after I changed to the old board back again to return the new faulty one, Charging was now not a problem anymore. Maybe I tightened one screw, which has been loose before?
Soeren -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 19
Últimos 30 dias: 75
Duração total: 7,338
