Introdução
Overtime, dust and other dirt particles can accumulate in the USB port. When the USB port is dirty, your phone may not be able to charge. If you’ve cleaned the USB port and your phone still does not charge, you may need to replace the USB port.
Since you need to open up the screen in order to access the USB port, please follow our screen replacement guide before taking further steps.
O que você precisa
Grab a suction cup tool and place it near the bottom of the phone.
Pull up on the suction cup to slightly lift the LCD Panel from the body of the phone.
Starting from the bottom, slide in a plastic opening tool between the gap of the LCD and the phone.
Using a combination of the plastic opening tool and picks, slide around the gaps to unhook the clips, unhinging the panel from the body of the phone.
Flip the phone screen towards the bottom of the device and lay the screen facing down.
Using a plastic spudger remove the battery connector ribbon cable by getting underneath the connector and gently lifting it off.
Using a plastic sudger remove the screen connector ribbon cable by lifting from the underneath.
After you remove the ribbon cable the panel should be free to remove and replace.
Remove the two 3.8mm Phillips #0 screws holding down the lower metal bracket.
8 outras pessoas executaram este guia.
2 comentários
Hey, I can only find those USB connector boards online where all the chips on it are missing. Does anyone know where I can find a proper replacement board?
Same problem for me. I just bought a "1:1 replacement" board, which has missing chips and does not allow data transfer. Charging was possible (only very slow). However, after I changed to the old board back again to return the new faulty one, Charging was now not a problem anymore. Maybe I tightened one screw, which has been loose before?
Soeren -
