Ir para o conteúdo principal
Xiaomi Mi 9 Rear Glass Replacement
O que você precisa
  1. Xiaomi Mi 9 Rear Glass Replacement, Rear Glass: passo 1, imagem 1 %32
    • Before you begin, switch off your phone.
    • Apply a heated iOpener to the rear glass to loosen the adhesive beneath the edges. Apply the iOpener for at least two minutes.
  2. Xiaomi Mi 9 Rear Glass Replacement: passo 2, imagem 1 %32 Xiaomi Mi 9 Rear Glass Replacement: passo 2, imagem 2 %32 Xiaomi Mi 9 Rear Glass Replacement: passo 2, imagem 3 %32
    • Secure a suction handle to the lower edge of the rear glass, as close to the edge as possible.
    • If the phone's rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the rear glass with the suction handle to create a gap between the glass and the frame.
    • Insert an opening pick into the gap.
    • If you have trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Slide the opening pick to the bottom right corner of the phone.
  3. Xiaomi Mi 9 Rear Glass Replacement: passo 3, imagem 1 %32 Xiaomi Mi 9 Rear Glass Replacement: passo 3, imagem 2 %32
    • Insert a second opening pick and slide it to the bottom left corner to cut the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. Xiaomi Mi 9 Rear Glass Replacement: passo 4, imagem 1 %32 Xiaomi Mi 9 Rear Glass Replacement: passo 4, imagem 2 %32 Xiaomi Mi 9 Rear Glass Replacement: passo 4, imagem 3 %32
    • Insert a third opening pick at the bottom left corner.
    • Start to slide the opening pick from the bottom left corner along the side of the Xiaomi Mi 9 to cut the adhesive.
    • Be aware of the rear cameras and only insert the tip of the opening pick. As the adhesive cools down it gets harder to cut. If necessary use your iOpener to reheat it.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  5. Xiaomi Mi 9 Rear Glass Replacement: passo 5, imagem 1 %32 Xiaomi Mi 9 Rear Glass Replacement: passo 5, imagem 2 %32
    • Insert a fourth opening pick under the top left corner of the rear glass.
    • Slide the opening pick along the top to cut the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. Xiaomi Mi 9 Rear Glass Replacement: passo 6, imagem 1 %32 Xiaomi Mi 9 Rear Glass Replacement: passo 6, imagem 2 %32
    • Insert a fifth opening pick at the top right corner of the phone.
    • Slide the opening pick along the right edge to cut the remaining adhesive.
  7. Xiaomi Mi 9 Rear Glass Replacement: passo 7, imagem 1 %32 Xiaomi Mi 9 Rear Glass Replacement: passo 7, imagem 2 %32
    • Carefully lift the rear glass and remove it.
    • Before installing new adhesive and reassembly, remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
Conclusão
Secure the new back cover with pre-cut adhesive or double-sided adhesive tape.
After installing the rear glass, apply pressure for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
Repair didn’t go as planned? Check out our Answers Community for troubleshooting help.
7 outras pessoas executaram este guia.
Dominik Schnabelrauch
Membro desde: 11/23/16
204.379 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 136
Autoria de 17.299 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 39
Últimos 30 dias: 151
Duração total: 19,018
