Ir para o conteúdo principal
Xiaomi Mi 9 Rear Camera Glass With Sensors Replacement
O que você precisa
  1. Xiaomi Mi 9 Rear Camera Glass With Sensors Replacement, Rear Glass: passo 1, imagem 1 %32
    • Before you begin, switch off your phone.
    • Apply a heated iOpener to the rear glass to loosen the adhesive beneath the edges. Apply the iOpener for at least two minutes.
  2. Xiaomi Mi 9 Rear Camera Glass With Sensors Replacement: passo 2, imagem 1 %32 Xiaomi Mi 9 Rear Camera Glass With Sensors Replacement: passo 2, imagem 2 %32 Xiaomi Mi 9 Rear Camera Glass With Sensors Replacement: passo 2, imagem 3 %32
    • Secure a suction handle to the lower edge of the rear glass, as close to the edge as possible.
    • If the phone's rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the rear glass with the suction handle to create a gap between the glass and the frame.
    • Insert an opening pick into the gap.
    • If you have trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Slide the opening pick to the bottom right corner of the phone.
  3. Xiaomi Mi 9 Rear Camera Glass With Sensors Replacement: passo 3, imagem 1 %32 Xiaomi Mi 9 Rear Camera Glass With Sensors Replacement: passo 3, imagem 2 %32
    • Insert a second opening pick and slide it to the bottom left corner to cut the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. Xiaomi Mi 9 Rear Camera Glass With Sensors Replacement: passo 4, imagem 1 %32 Xiaomi Mi 9 Rear Camera Glass With Sensors Replacement: passo 4, imagem 2 %32 Xiaomi Mi 9 Rear Camera Glass With Sensors Replacement: passo 4, imagem 3 %32
    • Insert a third opening pick at the bottom left corner.
    • Start to slide the opening pick from the bottom left corner along the side of the Xiaomi Mi 9 to cut the adhesive.
    • Be aware of the rear cameras and only insert the tip of the opening pick. As the adhesive cools down it gets harder to cut. If necessary use your iOpener to reheat it.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  5. Xiaomi Mi 9 Rear Camera Glass With Sensors Replacement: passo 5, imagem 1 %32 Xiaomi Mi 9 Rear Camera Glass With Sensors Replacement: passo 5, imagem 2 %32
    • Insert a fourth opening pick under the top left corner of the rear glass.
    • Slide the opening pick along the top to cut the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. Xiaomi Mi 9 Rear Camera Glass With Sensors Replacement: passo 6, imagem 1 %32 Xiaomi Mi 9 Rear Camera Glass With Sensors Replacement: passo 6, imagem 2 %32
    • Insert a fifth opening pick at the top right corner of the phone.
    • Slide the opening pick along the right edge to cut the remaining adhesive.
  7. Xiaomi Mi 9 Rear Camera Glass With Sensors Replacement: passo 7, imagem 1 %32 Xiaomi Mi 9 Rear Camera Glass With Sensors Replacement: passo 7, imagem 2 %32
    • Carefully lift the rear glass and remove it.
    • Before installing new adhesive and reassembly, remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
  8. Xiaomi Mi 9 Rear Camera Glass With Sensors Replacement, Motherboard Cover with Charging Coil: passo 8, imagem 1 %32
    • Remove the ten Phillips #00 screws (3 mm length) that secure the motherboard cover.
    • There might be tamper proof sticker on some of the screws.
  9. Xiaomi Mi 9 Rear Camera Glass With Sensors Replacement: passo 9, imagem 1 %32 Xiaomi Mi 9 Rear Camera Glass With Sensors Replacement: passo 9, imagem 2 %32
    • Insert an opening pick at the top right corner of the motherboard cover.
    • Twist the opening pick sideways to pry up and slightly lift the motherboard cover.
  10. Xiaomi Mi 9 Rear Camera Glass With Sensors Replacement: passo 10, imagem 1 %32 Xiaomi Mi 9 Rear Camera Glass With Sensors Replacement: passo 10, imagem 2 %32
    • Carefully remove the motherboard cover including the charging coil / NFC antenna.
  11. Xiaomi Mi 9 Rear Camera Glass With Sensors Replacement, Battery Disconnect: passo 11, imagem 1 %32 Xiaomi Mi 9 Rear Camera Glass With Sensors Replacement, Battery Disconnect: passo 11, imagem 2 %32
    • Use a spudger to pry up and disconnect the battery flex cable.
  12. Xiaomi Mi 9 Rear Camera Glass With Sensors Replacement, Rear Camera Glass with Sensors: passo 12, imagem 1 %32 Xiaomi Mi 9 Rear Camera Glass With Sensors Replacement, Rear Camera Glass with Sensors: passo 12, imagem 2 %32
    • Use the flat end of a spudger to pry up and disconnect the sensor cable of the rear camera glass.
  13. Xiaomi Mi 9 Rear Camera Glass With Sensors Replacement: passo 13, imagem 1 %32 Xiaomi Mi 9 Rear Camera Glass With Sensors Replacement: passo 13, imagem 2 %32
    • Remove the rear camera glass.
Conclusão
Repair didn’t go as planned? Check out our Answers Community for troubleshooting help.
5 outras pessoas executaram este guia.
Dominik Schnabelrauch
Membro desde: 11/23/16
210.026 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 141
Autoria de 17.895 guias
Um comentário
Hi, I need the part number of the cover with the sensors. The sensors are not working in my device.
Robert Lawrowski - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 20
Últimos 30 dias: 71
Duração total: 5,902
