Introdução
Use this guide to remove or replace the rear glass of the Xiaomi Mi 8.
You’ll need replacement adhesive to reattach components when reassembling the device.
Ferramentas
Peças
Nenhum componente especificado.
Apply a heated iOpener to the rear glass to loosen the adhesive beneath the edges. Apply the iOpener for at least two minutes.
Secure a suction handle to the lower edge of the rear glass, as close to the edge as possible.
Lift the rear glass with the suction handle to create a gap between the glass and the frame.
Insert an opening pick into the gap.
Slide the opening pick to the bottom right corner of the phone.
Insert a third opening pick at the bottom left corner.
Start to slide the opening pick from the bottom left corner along the side of the Xiaomi Mi 8 to cut the adhesive.
As the adhesive cools down it gets harder to cut. If necessary use your iOpener to reheat it.
Leave the opening pick in the top left corner to prevent the adhesive from resealing.
Secure the new back cover with pre-cut adhesive or double-sided adhesive tape.
After installing the rear glass, apply pressure for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
Repair didn’t go as planned? Check out our Answers Community for troubleshooting help.
2 outras pessoas concluíram este guia.
