Ir para o conteúdo principal
Xiaomi Mi 4 Rear Facing Camera Replacement
O que você precisa
  1. Xiaomi Mi 4 Rear Facing Camera Replacement, Rear Case/Midframe: passo 1, imagem 1 %32 Xiaomi Mi 4 Rear Facing Camera Replacement, Rear Case/Midframe: passo 1, imagem 2 %32 Xiaomi Mi 4 Rear Facing Camera Replacement, Rear Case/Midframe: passo 1, imagem 3 %32
    • Check to make sure that the device is powered off.
    • Use a pin or paper clip to insert in the hole on the side of the phone next to the micro SIM cardholder to remove the tray.
    • Remove the SIM card tray from the Xiaomi Mi 4 and store it somewhere safe.
  2. Xiaomi Mi 4 Rear Facing Camera Replacement: passo 2, imagem 1 %32 Xiaomi Mi 4 Rear Facing Camera Replacement: passo 2, imagem 2 %32 Xiaomi Mi 4 Rear Facing Camera Replacement: passo 2, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Metal Spudger
    $2.99
    Comprar
    • Using the flat metal spudger and curved metal spudger, make a wedge between the plastic back cover and the inner frame
    • Using the second spudger, slowly work your way around the perimeter of the device
    • Listen for clicking sounds as you are prying the back cover away from the frame
    • As the back cover is almost completely removed, use the suction-cup tool to remove the plastic cover without damaging the back
  3. Xiaomi Mi 4 Rear Facing Camera Replacement: passo 3, imagem 1 %32 Xiaomi Mi 4 Rear Facing Camera Replacement: passo 3, imagem 2 %32 Xiaomi Mi 4 Rear Facing Camera Replacement: passo 3, imagem 3 %32
    • Use a 000 phillips head screwdriver to remove the 10 1.2mm phillips head screws in the plastic frame that hold the motherboard and battery.
    • Use a 000 phillips head screwdriver to remove the 3 0.5mm phillips head screws in the plastic frame that hold the motherboard and battery.
    • Use the small plastic opening tool and place it in the slot on the bottom right corner of the inner frame and carefully pry it off.
  4. Xiaomi Mi 4 Rear Facing Camera Replacement, Battery: passo 4, imagem 1 %32 Xiaomi Mi 4 Rear Facing Camera Replacement, Battery: passo 4, imagem 2 %32 Xiaomi Mi 4 Rear Facing Camera Replacement, Battery: passo 4, imagem 3 %32
    Comprar
    • Use tweezers to gently disconnect the connections that run across the battery and are connected to the motherboard.
    • Proceed to gently remove the tape like connector from the battery until it is completely off.
    • Use tweezer to disconnect battery’s wire from the motherboard.
  5. Xiaomi Mi 4 Rear Facing Camera Replacement: passo 5, imagem 1 %32 Xiaomi Mi 4 Rear Facing Camera Replacement: passo 5, imagem 2 %32
    • Use the plastic opening tool to gently pry the battery out of its casing for removal.
  6. Xiaomi Mi 4 Rear Facing Camera Replacement, Motherboard: passo 6, imagem 1 %32
    Comprar
    • With the battery removed locate the left-hand cable connected to the motherboard. With the tweezers, firmly grasp the wires of the connector and gently disconnect the cable from the motherboard.
    • Find the other cable connecting the motherboard to the device at the top right-hand side of the phone, and carefully use the tweezers to remove that as well.
  7. Xiaomi Mi 4 Rear Facing Camera Replacement: passo 7, imagem 1 %32 Xiaomi Mi 4 Rear Facing Camera Replacement: passo 7, imagem 2 %32
    • Wedge the plastic opening tool, between the motherboard and the inner region of the phone in the slot atop the motherboard.
  8. Xiaomi Mi 4 Rear Facing Camera Replacement, Rear Facing Camera: passo 8, imagem 1 %32 Xiaomi Mi 4 Rear Facing Camera Replacement, Rear Facing Camera: passo 8, imagem 2 %32
    • With the motherboard removed from the device, turn the motherboard over to face the obverse side.
    • Locate the connector for the rear camera.
  9. Xiaomi Mi 4 Rear Facing Camera Replacement: passo 9, imagem 1 %32 Xiaomi Mi 4 Rear Facing Camera Replacement: passo 9, imagem 2 %32 Xiaomi Mi 4 Rear Facing Camera Replacement: passo 9, imagem 3 %32
    Comprar
    • Grasp the cable with the tweezers and gently pull up and away from the motherboard to disconnect it.
Conclusão
6 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 15-6, Blackwell Fall 2015 Membro de USF Tampa, Team 15-6, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G6
Membros da 2
Autoria de 11 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 13
Duração total: 4,363
