Ir para o conteúdo principal
Xiaomi Mi 4 Rear Case/Midframe Replacement
O que você precisa
  1. Xiaomi Mi 4 Rear Case/Midframe Replacement, Rear Case/Midframe: passo 1, imagem 1 %32 Xiaomi Mi 4 Rear Case/Midframe Replacement, Rear Case/Midframe: passo 1, imagem 2 %32 Xiaomi Mi 4 Rear Case/Midframe Replacement, Rear Case/Midframe: passo 1, imagem 3 %32
    • Check to make sure that the device is powered off.
    • Use a pin or paper clip to insert in the hole on the side of the phone next to the micro SIM cardholder to remove the tray.
    • Remove the SIM card tray from the Xiaomi Mi 4 and store it somewhere safe.
  2. Xiaomi Mi 4 Rear Case/Midframe Replacement: passo 2, imagem 1 %32 Xiaomi Mi 4 Rear Case/Midframe Replacement: passo 2, imagem 2 %32 Xiaomi Mi 4 Rear Case/Midframe Replacement: passo 2, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Metal Spudger
    $2.99
    Comprar
    • Using the flat metal spudger and curved metal spudger, make a wedge between the plastic back cover and the inner frame
    • Using the second spudger, slowly work your way around the perimeter of the device
    • Listen for clicking sounds as you are prying the back cover away from the frame
    • As the back cover is almost completely removed, use the suction-cup tool to remove the plastic cover without damaging the back
  3. Xiaomi Mi 4 Rear Case/Midframe Replacement: passo 3, imagem 1 %32 Xiaomi Mi 4 Rear Case/Midframe Replacement: passo 3, imagem 2 %32 Xiaomi Mi 4 Rear Case/Midframe Replacement: passo 3, imagem 3 %32
    • Use a 000 phillips head screwdriver to remove the 10 1.2mm phillips head screws in the plastic frame that hold the motherboard and battery.
    • Use a 000 phillips head screwdriver to remove the 3 0.5mm phillips head screws in the plastic frame that hold the motherboard and battery.
    • Use the small plastic opening tool and place it in the slot on the bottom right corner of the inner frame and carefully pry it off.
Conclusão
9 outras pessoas executaram este guia.
Robert Cobaich
Membro desde: 09/03/15
2.082 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 16-1, Blackwell Winter 2016 Membro de USF Tampa, Team 16-1, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G1
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 30
Duração total: 4,342
