Introdução
Use this guide to replace a faulty motherboard in your Xiaomi Mi 3 smartphone.
The motherboard is a piece of hardware that allows for components of a phone – such as RAM, CPU, memory, and other components – to communicate with each other. A faulty motherboard will make your phone unable to boot up or cause it to frequently crash. It can be damaged by an overheating battery, dropping the phone, or using incompatible chargers.
Be aware that an improperly installed battery can lead to overheating and swelling of the battery, which can further damage the motherboard and potentially cause a fire.
Before beginning, make sure to power off your phone completely and disconnect from any external power source.
O que você precisa
Firmly press the SIM card removal tool into the hole located at the top of the phone to eject the SIM card tray from the slot.
Place the front panel screen side down with the camera at the top.
Remove these six Phillips head screws located at the upper half of the phone.
This screw is located under an orange sticker at the top right corner of the panel. The sticker can be removed with a pair of tweezers, then remove that Phillips head screw.
Disconnect the antenna wire that is attached to the lower left side of the motherboard using the pry tool.
8 outras pessoas executaram este guia.
7 comentários
Mi have problems with my mother board i am nt getting it anywhere in the servce center sggst me where i can get it.
I know one in the Moscow)
I can send to you bricked mainboard. Unsucsessful flashing, but you can rise up it in 9008 mode. If interesting - write to me.
My sound is little bit cracking, what to do..plz help me.
