Ir para o conteúdo principal
Xiaomi Air 12 Speaker Replacement
O que você precisa
  1. Xiaomi Air 12 Speaker Replacement, Rear Casing: passo 1, imagem 1 %32
    • Orient the computer so the Xiaomi logo is at the bottom of the device.
  2. Xiaomi Air 12 Speaker Replacement: passo 2, imagem 1 %32 Xiaomi Air 12 Speaker Replacement: passo 2, imagem 2 %32 Xiaomi Air 12 Speaker Replacement: passo 2, imagem 3 %32
    • Insert the plastic opening tool underneath the top-middle rubber covering and lift upwards to reveal the hidden screw.
  3. Xiaomi Air 12 Speaker Replacement: passo 3, imagem 1 %32 Xiaomi Air 12 Speaker Replacement: passo 3, imagem 2 %32
    • Remove the eight 3 mm screws using the Torx T5 driver by inserting the screwdriver into each screw and rotating counterclockwise.
  4. Xiaomi Air 12 Speaker Replacement: passo 4, imagem 1 %32 Xiaomi Air 12 Speaker Replacement: passo 4, imagem 2 %32 Xiaomi Air 12 Speaker Replacement: passo 4, imagem 3 %32
    • Insert the plastic opening tool into each side of the computer and push the tool downwards to pop open the back cover.
    • You will hear popping noises as you remove the cover.
  5. Xiaomi Air 12 Speaker Replacement: passo 5, imagem 1 %32 Xiaomi Air 12 Speaker Replacement: passo 5, imagem 2 %32
    • Remove the back of the laptop by gently lifting the casing upwards.
  6. Xiaomi Air 12 Speaker Replacement, Speaker: passo 6, imagem 1 %32 Xiaomi Air 12 Speaker Replacement, Speaker: passo 6, imagem 2 %32
    • Remove the white and black speaker wires from the black tabs by pulling upwards from the device.
  7. Xiaomi Air 12 Speaker Replacement: passo 7, imagem 1 %32 Xiaomi Air 12 Speaker Replacement: passo 7, imagem 2 %32
    • Gently pull the speaker connector out from the connection point using your hand.
  8. Xiaomi Air 12 Speaker Replacement: passo 8, imagem 1 %32 Xiaomi Air 12 Speaker Replacement: passo 8, imagem 2 %32 Xiaomi Air 12 Speaker Replacement: passo 8, imagem 3 %32
    • Remove the left speaker module by pulling the panel up from the device.
    • Repeat the same process for the right speaker module.
    • Left and Right speaker modules are denoted by an "L" and "R" respectively.
    • There will be a slight adhesive underneath the module.
Conclusão
Hannah Kwan
Membro desde: 04/18/18
839 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S18-G4, Livingston Spring 2018 Membro de Cal Poly, Team S18-G4, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G4
Membros da 4
Autoria de 20 guias
6 comentários
Thanks for the tutorial! But where can i buy replacement speakers? My right speaker is overdriving all the time now, giving me a lot of loud buzz noises.
Nicolai - Responder
The same for me. I’d like to replace the speakers because one of them is “crackling/vibrating”, but i don’t know where to buy them…
Maniac 45 - Responder
same problem, mine at >50% vibrating very bad
isman87 - Responder
have you found them? i need those too
Giorgio Pianesi -
Hello, i love this laptop and its been my companion for almost 3 years think the audio input jack got grounded because i heard a creaking sound when i inserted a metallic headset jack, the device was charging when it happened. Now the audio output from the audio jack port is like a minus one or somewhat instrumental. Any suggestions what to do?
James Prae Liclican - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 20
Duração total: 1,036
